Suspension torque specs
Old Dec 7, 2004 | 06:37 PM
Mr. Francesco's Avatar
Default Suspension torque specs
My tein flex should be here this week, and i am going to install them myself. I have used the search, but i can not find torque specs for the suspension.
What is the factory torque specs for the top two strut bolts front and rear?
What is the torque specs for the lower bolt on the arms?
Thanks alot guys if you know this one
Old Dec 7, 2004 | 06:44 PM
meth's Avatar
i think i torqued the bolts on top to 35lbs however, that is probably not factory spec. and the bottom one i forgot what it was. you will also need the spec for the upper a-arms for the front.
Old Dec 8, 2004 | 07:17 AM
hum, i hope others chime in. thanks though
Old Dec 8, 2004 | 06:28 PM
Mok's Avatar
Mok
hope this helps
suspension torque
top nut 22
pair of 2 top bolts 36
bottom bolt 47
2 A-arm bolts 76
rear stb 32
Old Dec 8, 2004 | 06:34 PM
revhi's Avatar
Whats up frank. Modding in the winter, a true enthusiest.
Old Dec 8, 2004 | 07:37 PM
Originally Posted by Mok,Dec 8 2004, 11:28 PM
hope this helps
suspension torque
top nut 22
bottom bolt 47
2 A-arm bolts 76
rear stb 32
you are the man. thanks alot
Old Dec 8, 2004 | 07:40 PM
you know it. now im broke, but its ok. Next im buying rims, then ill get a wing and lip. I need to be ready for the shows this summer.
Hopefully come summer ill work on the engine a little more, im still thinking about a turbo kit or SC.
Anyway, if you want to check the teins out let me know. Its going to take me a while to learn how to set them and adjust them right.
GreenmanS2000
Feb 25, 2015 10:59 AM
SCZ4
Jan 17, 2013 11:52 PM
FISH22
Aug 24, 2006 01:26 PM
WarrenW
Aug 11, 2005 05:46 PM
WarrenW
Aug 11, 2005 05:00 AM
