Switch from KPH to MPH?
Old Jan 14, 2007 | 08:17 AM
purehonda's Avatar
Default Switch from KPH to MPH?
I can see the unlit mph but I can't figure out how to switch it to MPH. It's a JDM so came set to KPH. I was wondering if there's a combination of buttons to swap the speedometer to MPH?
thanks
Old Jan 14, 2007 | 08:29 AM
r2d2's Avatar
just push and hold left from the right two buttons. it'll switch.
Old Jan 14, 2007 | 08:44 AM
purehonda's Avatar
this isn't my s2k
http://www.superficial.net/images/wp-site/.../s2000-dash.jpg
so u are saying to press and hold the right two buttons?
Old Jan 14, 2007 | 09:04 AM
S2K KiDD's Avatar
just hold down the SEL button it will switch
Old Jan 14, 2007 | 09:08 AM
purehonda's Avatar
also will it stay switched or will it reset every time i start the car?
Old Jan 14, 2007 | 09:16 AM
Enthralled's Avatar
no,it'll stay that way until you switch it yourself.
Old Jan 14, 2007 | 09:20 AM
purehonda's Avatar
k gonna try it now.
Old Jan 14, 2007 | 09:32 AM
purehonda's Avatar
the JDM's must be KPH only. I press and held that button for about 2 mins no luck. It does not say "SEL" on mine though. But it's the on right next to the trip button. Any ideas?
Old Jan 14, 2007 | 09:38 AM
purehonda's Avatar
found info:
Japanese Market (JDM) Clusters
All clusters fitted to Japanese cars do not have the ability to switch from KPH/MPH - the button is present but performs no function so the display is in KPH ONLY. I can enable this button for you when converting the cluster.
Additionally, if you have just imported an S2000 and are required to convert it to MPH for an ESVA test then please contact me for just this service alone - details are on the order page. When I have re-enabled the button the odometer and dual trip counters can be toggled between MPH/KPH at will - the readings which are also converted when you switch which makes for a better result than simply wiring in a speedo converter module.
Old Jan 14, 2007 | 10:42 AM
gomarlins3's Avatar
Originally Posted by purehonda,Jan 14 2007, 11:38 AM
found info:
That sucks.
raydouble
May 16, 2014 02:41 PM
Dubs2k
Oct 16, 2009 09:28 AM
ahuynh31
Sep 8, 2008 12:38 PM
*autospec*
Feb 11, 2005 12:57 PM
