test pipe question
Old Jul 28, 2008 | 10:19 PM
NorthWestS2000's Avatar
Default test pipe question
If i hvae a Hks exhaust do i have to run a hks test pipe? or will any type bolt up?
Just want to make sure before i order
Old Jul 28, 2008 | 10:52 PM
so i guess what im asking is, is the bolt pattern on my exhaust the same as anyother test pipes bolt pattern
Old Jul 28, 2008 | 11:09 PM
auto2nr1's Avatar
yes, you can run pretty much any test pipe with your hks exhaust
Old Jul 28, 2008 | 11:50 PM
s2k aok's Avatar
i'd assume so...
Old Jul 29, 2008 | 05:10 AM
EVAN&MONICA's Avatar
Id assume so as well, as long as its the same length
Old Jul 29, 2008 | 07:28 AM
vtec9's Avatar
Only absolute morons would have some special bolt pattern that wouldn't match up to the car's stock catalytic converter, and thus, any aftermarket TP. I will assume HKS isn't run by morons, so you can use any TP. Likewise, this assumes every other company isn't run by morons and produced TPs with the same bolt pattern and length as the stock cat.. which is a safe bet.
Old Jul 29, 2008 | 10:13 AM
Enthralled's Avatar
just make sure to get one that was made for the S2000!!
Old Jul 29, 2008 | 10:15 AM
ian05s2k's Avatar
Yea, you can run any test tipe. It may be a good idea to match piping diameter as well though so you dont create a bottle neck effect in your exhaust.
-Ian
Old Jul 29, 2008 | 01:43 PM
s2k dre's Avatar
yup all the test pipes are the same length and same bolt pattern.
Old Jul 29, 2008 | 01:46 PM
dorikin_86's Avatar
anybody have their rear bumpers 'blackened' because of the test pipe?
