Is there such a thing as the "immobilizer unit"?
Had my car flat bedded to the dealership Tuesday. The service manager called me and said that they needed to order a new "immobilizer unit" and that it would be overnighted so that it can be installed on Wednesday. Just wanted to check to see if I'm being BS'ed or is there really a part referred to as the immobilizer unit.
Thanks -- Tom
Thanks -- Tom
ISSUE RESOLVED
According to my service rep, my Immobilizer and Transponder were both replaced.
I forgot to look at the work order printout that they gave me last night to see if it listed the actual part numbers that were replaced. I will check when I get home and post the information if it is on the printout.
Thanks for your help.
-- Tom
-- Tom
Originally posted by jpsc
Can someone tell me where the security system is installed
on the s2000? I need to adjust the sensitivity settings
thanks,
John
thanks,
John
The installation instructions are available in PDF format from Trevor's HandA-Accessories Web site: http://www.handa-accessories.com/S2000/s2ksecurity.pdf
I also just returned from a trip to find the S2000 will not start with any of the 3 keys. It turns over, but will not fire up. Has anyone had success without the trip to dealership? My confidence in the local dealer is very low on this car. HELP!
Mark, on your dash there is a light for the immobilizer. Under normal conditions it blinks for a few seconds then stops. Does your's stop blinking? If not then you may have the same problem that I had.
In my case the dealership had to replace two parts. I've had no trouble since then.
If you local dealership can not figure out the problem, have them give my dealership a call.
Please let us know if your problem ends up being the same as mine.
-- Tom
-- Tom
