Thinking about 4.44 gears...
Is the stock final gear and the Ap2 4.1, and would it be a better to go with the 4.44's or the 4.57's? I'm trying to figure out if going with the 4.57's on n AP2 may be a bit much.
xviper you mentioned that basically a stock AP2 is like aAp1 with 4.44's. So if I was to say put 4.57's in the AP2 wouldI be correct in saying that it would be as if I was putting 4.77's into the AP1?
If so hen I think 4.57' may be a bit much for the AP2, and the better choice might be 4.44's. Any ideas/ suggestions?
you are correct HvRRZ.
the 4.44's in an ap2 will make you perform almost as good as a 4.57 ap1. i agree with you, i think the 4.57 in your ap2 would take away a bit too much top end for my taste.
FYI
Here is the Transmission gear ratios
JDM MY05
1st gear 3.133
2nd gear 2.045
3rd gear 1.481
4th gear 1.161
5 speed 0.970
6 speed 0.810
Retreat 2.800
Final (diff) 4.100
Primary Gear Reduction 1.160
USDM MY04+
1st gear 3.133
2nd gear 2.045
3rd gear 1.481
4th gear 1.161
5th gear 0.942
6th gear 0.763
Reverse: 2.800
Final Drive Ratio 4.100
Primary Gear Reduction 1.208
USDM MY03-
1st gear 3.133
2nd gear 2.045
3rd gear 1.481
4th gear 1.161
5th gear 0.971
6th gear 0.811
Reverse: 2.800
JDM MY05
1st gear 3.133
2nd gear 2.045
3rd gear 1.481
4th gear 1.161
5 speed 0.970
6 speed 0.810
Retreat 2.800
Final (diff) 4.100
USDM MY04+
1st gear 3.133
2nd gear 2.045
3rd gear 1.481
4th gear 1.161
5th gear 0.942
6th gear 0.763
Reverse: 2.800
USDM MY03-
1st gear 3.133
2nd gear 2.045
3rd gear 1.481
4th gear 1.161
5th gear 0.971
6th gear 0.811
Reverse: 2.800
Originally Posted by HvRRZ,Aug 10 2005, 10:05 AM
xviper you mentioned that basically a stock AP2 is like aAp1 with 4.44's.*
So if I was to say put 4.57's in the AP2 wouldI be correct in saying that it would be as if I was putting 4.77's into the AP1?**
If so hen I think 4.57' may be a bit much for the AP2, and the better choice might be 4.44's. Any ideas/ suggestions?***
** It might be much more than 4.77s. Use the Reverend's gear calculator to crunch all the number so you know exactly what you are getting into. I don't recall the precise numbers, but it was closer to 5.0 (in the first 4 gears). 5th and 6th will only be slightly different from AP1 to AP2 with the same final drive gearing.
*** ONLY in the first 4 gears. 5 and 6 will act similar to an AP1 with the same FD. You cannot be a slow shifter or you will lose the advantage that the gearing will give you.
edit: The assumption must be made to allow for drag limited top speed.
Originally Posted by Wisconsin S2k,Aug 10 2005, 02:09 PM
if you went with 4.57 in your ap2/f22:
top speed is now 135mph.
1st redlines at: 33mph
2nd: 50mph
3rd: 70mph
4th: 90mph
5th: 110mph
So IMO 4.57 would be pretty short.
2nd: 50mph
3rd: 70mph
4th: 90mph
5th: 110mph
I am only doing 4500rpm @ 80.
