Thinking about 4.44 gears...
Old Aug 11, 2005 | 09:27 AM
  #31
xviper's Avatar
Originally Posted by HvRRZ,Aug 11 2005, 10:02 AM
Thank you xviper for the link.
Strange though becuse I have been able to recently hit 155 on a straight with a decent acceleration in the speed. Fairly slow but for what it wasit got up there pretty fast unil about 145 where the climb became slower. I understand the cars drag limitatios, but you menioned the th gear in the ap2 being limited to aout 150. Do you mean that the gear itself is limited to about 150, or tht it cannot spin faster to get the higher speeds? This could be because of the amount of power the S produces.
Also if reverends gear calulator is correct in it's calculations then it seems that a ap1 with 4.57's is just about the same as an ap2 with 4.3's. Maybe 4.3's would actually be a good choice. The calculations are a bit strange though because by just changing the width of the tires, the speed top speed of each gear seems to go up. I'm planning to upgrade to a lighter set up for the wheels, as well as getting 275 in the rear. with 275 it calculatesthe top speed even with the 4.3's to be above 160mph. I always though wider tires would make a car loss a bit of top speed.
Like I said, "Give or take". This depends upon the speedometer error of your car and grade on which you are driving and the wind at the time and slight variations in power output of each individual car.
The AP2 is geared to go about 150. That is to say, it's reached redline in 6th. The point is, even if you geared it to go faster, it is not likely to go faster due to the available HP and torque the engine puts out.
You may be using the gear calculator incorrectly. I see a difference of about 5 mph for the two examples you cited.
Changing the width of the rear tires will change the amount of center tread flex, thus changing the overall diameter of the tire itself at speed. This is like changing the gearing. However, like changine the gearing, the car won't physically go any faster if it has already reached its drag limit.
35 cent
Jun 7, 2006 02:50 PM
ahbongkadah
Nov 24, 2005 05:56 AM
kinetica
Sep 24, 2005 12:17 PM
X_s2k_X
Apr 15, 2004 05:44 PM
