? for those with koni yellows...
What parts do you need to take off the stock shocks to use w/ the koni's?
What setting do you guys find is the best for street driving (mine is a daily driver)??
TIA
TIA
question 2)from full firm to full soft, it takes two full turns. from full stiff, turn it one complete turn and it'll be perfect for a daily driver. firm enough, but not bone jarring.
Is there distinct notches? What happens if you go more the 2 full turns? Im just curious, I have bought a set and on one you can feel it notch and the others you cant. Seems a bit weird to me.
Dale
Dale
There are no distinct notches, but you will feel the resistance at the end of its range. If you haven't installed the shocks on the car and tried to turn the knob, you may be turning the entire shaft. I did that when I first got it and could not feel it stop turning. You should be turning only the small tab on the very top of the shaft, and not the entire shaft. Hope this helps.
