For those with Proflow's TB
Old Apr 1, 2002 | 06:28 PM
warpspeed's Avatar
Default For those with Proflow's TB
I've got idling problems and was wondering if anyone else with Proflow's TB has the same? I've had everything checked out from new plugs, valves adjusted, compression test. The hotter it gets outside the worst it seems. Any help? Thanks.
Old Apr 1, 2002 | 07:19 PM
RT's Avatar
RT
Try moving (rotating) your TPS ever so slightly one way and if that makes it worse then 2x ever so slightly the other way
Good Luck
Old Apr 1, 2002 | 09:12 PM
Fastlane's Avatar
I only experienced it once at a red light, I had been driving alot and it was also a warm day. The rpm kept going under 500 and correcting itself, if the problem would have continued , I would have deffinetly contacted PFlow.
Old Apr 2, 2002 | 04:09 PM
warpspeed's Avatar
top
Old Apr 2, 2002 | 04:44 PM
jerrypeterson's Avatar
Sounds more like heat soak than anything. Did you check throttle position sensor like Ray suggested?
Old Apr 2, 2002 | 05:24 PM
warpspeed's Avatar
Not yet, I'm waiting for the weekend when I have more time. Thanks.
Old Apr 2, 2002 | 10:11 PM
RT's Avatar
RT
Shouldn't take more than a couple ten minutes.
Don't forget to reset the ECU after:
https://www.s2ki.com/faqs/showfaq.php?threadid=17414
Old Apr 2, 2002 | 11:44 PM
socal28's Avatar
How long have you had it? Any problems before, or this problem started right after you installed it?
Had mine for about 9 months and no problems.
jsenclosure
Jul 5, 2017 12:54 PM
mumbler
Jul 17, 2006 10:36 AM
flow
May 7, 2004 11:18 PM
high on nine
Jul 10, 2003 07:19 AM
CG
Jun 21, 2001 08:12 PM
