tire pressure
32 psi is about as cushy as you're going to get. Many report that for performance reasons, higher pressures are the way to go so that translates to an even harsher ride. I'm running 34 psi but I've seen some posting pressures as high as 40 psi for certain kinds of track use.
Originally posted by banco
tire pressure
using 32psi on all tires, I feel every little bump...what pressure are you guys using?
red on black.....
tire pressure
using 32psi on all tires, I feel every little bump...what pressure are you guys using?red on black.....
Seriously though, 32 is probably as soft as you can go without increased tire wear, bubbles in the sidewalls, etc.
I hadn't been carefully watching my tire pressure and had let it fall into the high 20's. After bringing it back up to 32 psi I noticed, as you have stated, a harder ride but along with that came the feel and better handling I am used to in the S2K.
I will deal with a little stiffer ride for the better handling.
Originally posted by Sideways
This car loves 35 or 36 lbs..try it, you will like it!
