Tire pressure in cold weather
I just picked up an 05 Silverstone/Black...I live in NY, and the temps have been hovering around 30F...I can see what other owners mean about being careful in the cold with the OEM Bridgestones as theres a lot of wheelspin if I launch agressively and the back steps out when banging into 2nd AND 3rd under hard acceleration.
Here's my Q (I did search b4 posting a new topic):
If the temp is around or below freezing, would increasing or decreasing the tire pressure a few PSI help or hurt traction either way? The fronts are brand new (I got the dealer to put new fronts on because one was torn from a rim curb) and the backs have good meat on them (the car has 8000 mi).
Thanks a lot...this forum was super helpful even b4 I got the car...I knew where the secret compartment was even b4 I picked it up!!!
Originally Posted by Tee-Dub,Jan 26 2008, 07:41 PM
buy a set of all season tires for the winter, or you will crash!
Always adjust your psi to be the factory pressures, but if you run a few psi low, the tire will sit fatter on the ground, which is better for dry or damp traction, but bad for mpg and bad in standing water or snow.
The main thing though is the tire compound on the OEM tires becomes hockey-puck hard below 40 degrees - the tires will just have little grip when its cold out no matter what pressure they have. Winter tires are designed to remain pliable when its very cold out, and you'll have more grip at any psi with the proper tires.
Thanks for the responses....Ive already conceded that I wont be driving in the snow, and the traction on cold pavement has been fine in regular, and even spirited driving in these cold temps unless I redline and hit the next gear hard...dipping into the throttle smoothly and redlining it even felt fine the few times I did it...I do take it easy on the throttle on turns though.
Would snow tires be better in the cold/rain than all-seasons--generally of course--I know there are alot of different brands out there.
If you don't plan on driving in the snow, all seasons may be better. The new studless snow tires tend to wear pretty quickly on dry pavement, especially when it gets warmer out. The OEM tires really aren't meant for wet, or especially cold.
Originally Posted by burn1010,Jan 26 2008, 09:20 PM
Doesnt help that I missed VSA by a year.
