Tire Pressure recommendation?
Old May 31, 2001 | 04:10 PM
sfkayaker's Avatar
205/55/16 S02 int he front
245/45/16 AVS Sports in the rear.
What tire pressure does anyone suggest? I wnet to a perf course and they jacked
up the pressure all roud to 40psi - don't know if I should use that on the road?
thanx
tim
Old May 31, 2001 | 05:23 PM
cdelena's Avatar
I think you will find 40 too high. I would suggest you experiment with 32 to 35 cold, which when hot will be ~34 to 38. Much higher and you will be giving up traction.
Old May 31, 2001 | 05:53 PM
MarkS2K's Avatar
Someone recommended 33 for all four tires. They found that it was a good pressure for general driving. Forgot who recommended it. I thought it was you cdelena.
Old May 31, 2001 | 07:27 PM
Utah S2K's Avatar
CD has the right info.....again.
Old May 31, 2001 | 08:13 PM
jschmidt's Avatar
This is the tire combo I'm currently running. How do you like it?
Old Jun 1, 2001 | 07:56 AM
Nin009's Avatar
I run mine at about 39 psi. I don't notice them being too loose, of course I have never really run them with less. I do notice that the car is extremely sensitive to throttle input. This could be the car, could be the tire pressure.
Last weekend a couple of us ran about 100 miles of canyons. I had my tires at 39 and never felt like I was anywhere near losing adhesion. At the end of the day, however, my right front was down to 16 psi. I'm not sure if I broke a bead or maybe picked up debris. It seems to be holding air now. Any thoughts?
Old Jun 1, 2001 | 08:05 AM
nibble's Avatar
It could be a very smal puncture or a nail stuck to tire. you have to put the tire in the water to find out. I had a tire runs out of air in 3-4 weeks. I couldn't figure it out so took it to the shop and they put it in the water and there were tiny bubbles like in beer.
cheers,
Old Jun 1, 2001 | 08:08 AM
cdelena's Avatar
[QUOTE]Originally posted by Nin009
[B]Any thoughts?
oldskooleskimo
May 27, 2010 10:21 PM
jeremiah89
Oct 15, 2007 11:12 AM
Saki GT
Jun 6, 2006 05:01 PM
Fasttimes!!
Apr 20, 2006 04:49 AM
genghiskwong
Jun 11, 2003 01:23 PM
