Top Damage
Old May 12, 2008 | 08:18 PM
ROTFLMAO's Avatar
BTW, for those that do use the 303 stuff, I am told by a 303 rep that when applying it to the top, it should be wiped off and not set to dry.
Old Apr 13, 2009 | 12:49 PM
starchland's Avatar
Is it sensible to use some type of protectant on the inside of the soft top?
Old Apr 15, 2009 | 05:30 PM
tien2's Avatar
Whats the best material to use to prevent the wear or tear holes?
Old Apr 15, 2009 | 05:45 PM
croftoncustoms's Avatar
I would put a re-enforces vynal, which is a type of vynal/plastic compound that has nyalon interwoven inside of it and is very thin and very strong. Put this material at the top corners of the top where the typicla slit occurs, i would also recommend putting this at the front where the latches are, because that area usually wears out as well. if you would like any more info or places to get that material pm me and i will be more then willing to lead you in the right direction.
RaggTop is a great cleane and protectant as well
Old Apr 15, 2009 | 05:52 PM
damcgee's Avatar
I'll second that question.
vos2k
Oct 11, 2011 10:14 PM
dmw16
Feb 4, 2007 05:16 AM
DaveA
Oct 31, 2005 10:30 AM
jyeung528
Oct 9, 2003 12:25 PM
Icemn2003
Apr 30, 2003 05:16 AM
