Top and Passenger Window Not Working
Hi all, hate to be the guy to join and immediately post a problem thread, but I’m at a loss for my loss of passenger PW and top.
We’ve checked and replaced the applicable fuses and tested power to the passenger window motor, which is receiving it.
No noises when trying to lower the top or the window. I can’t find any info on this so it must not be a common problem.
Next step: window regulator? Another thought, is there a part of this car where water gets in and potentially shorts something out?
thank you!
thank you!
thank you!
thank you!
Unfortunately the top & the passenger window are controlled by
I say unfortunately as this unit is no longer supplied by Honda. You will have to start looking around the seconf hand parts market I'm afraid.
Honda S2000 convertible roof control unit ECU Module Relay 86500-S2A-003 99-09.
thank you!
thank you!
On my '06 the passenger window lock switch on the drivers door (photo in post #4) only controls the passenger window and has no effect on the roof. Lowering -- or raising -- the roof lowers both the driver's and passenger window regardless of the position that switch. I was curious enough to physically confirm this minutes ago. Roof won't budge unless the parking brake is set but it has no effect on the windows. I suspect this switch is a sedan safety leftover to prevent children in the back seat from playing with the window.
I lock the window switches on my other cars when my Dachshunds are in the car as they like look out the windows and when they stand on the switch they lower the window. Especially amusing at a drive thru window or toll plaza. Not been a problem in the Honda.
-- Chuck
-- Chuck
-- Chuck
-- Chuck
"Originally Posted by costcopizza
Driver window is fine. Passenger window doesn’t work from either the driver switch or the passenger."
Thanks for the responses, all.
