torque steer issues
Old Jan 31, 2007 | 03:45 PM
Aze85's Avatar
torque steer is for fwd cars...
Old Jan 31, 2007 | 04:02 PM
silentdancer's Avatar
he has the new jdm fwd conversion
Old Jan 31, 2007 | 06:14 PM
afwfjustin's Avatar
It's your tire pressure Get that straightened out and you'll be fine.
Hint, one of your tires on the drivers side (probably drive wheel) is very low on air
Old Jan 31, 2007 | 06:39 PM
[AP2-2NV]'s Avatar
air pressure.. .if not
make sure both rear tires are the same size, have the same mileage, and have the proper rotation.
Old Jan 31, 2007 | 07:05 PM
gomarlins3's Avatar
Originally Posted by SheDrivesIt,Jan 31 2007, 05:12 PM
Another question for the OP. Are all your tires the same type and mileage? A difference in tread depth from right to left could cause problems as the diameters would be different.
Very true. I have had this same issue twice. The first time was because I had two VERY different tire pressures in the rear due to a nail in one tire. The second time was due to me buying used rear tires and where not the same circumference (one had been used for more miles than the other). Once I switched to different rear tires, the problem went away. Worst case senario- your diff is going out, but that's highly unlikely.
Old Jan 31, 2007 | 08:07 PM
Planets's Avatar
I believe this could also be a symptom of the worn CV joint issue. If worse comes to worse and tire pressures don't fix the problem, you may want to check out this DIY thread:
https://www.s2ki.com/forums/index.php?showtopic=241367
wavelet
May 15, 2006 07:28 PM
Jaydem
Feb 14, 2006 08:57 AM
Thomas Guide
Feb 6, 2005 09:58 AM
Kenny_Stang
Oct 1, 2004 04:47 AM
Icemn2003
Nov 3, 2003 11:28 AM
