Traction
Is there a button to turn the traction off? If not how can I turn it off!
Drive with a very heavy foot on cold days with cold S02s.
Seriously there is no traction control on the S2000 so there is no way to disable something that is not there. You may be confusing "traction control" with the Torsen (torque sensing) limited slip differential (LSD except it is not the kind we had in the 60s
) which the S2000 does have.The LSD is a purely mechanical device and is always operational. It is not traction control because you can spin the tires at will with the S2000, it just distributes the torque to both rear wheels if they have equal grip or shifts it as nescessary to the tire that has the most grip.
Hope that helps
