Tranny Fluid? Suggestions?
Old Jul 11, 2004 | 10:22 AM
S2KNormR1's Avatar
Default Tranny Fluid? Suggestions?
It's about that time to do my 30,000 mile service which means changing the tranny fluid. Anyone have any suggestions on different ones that would make for a smoother tranny? I've heard about some here and there but I can't remember names...or should I just use the normal generic Honda tranny fluid? Suggestions would be great ...Thanks
Norm
Old Jul 11, 2004 | 12:21 PM
Driv300mph's Avatar
A lot of people suggest plain ol' Honda MTF
I'm going to be using LE-607 for my Differential and I'm gonna use Red Line for my Tranny...
Old Jul 11, 2004 | 12:32 PM
S2KNormR1's Avatar
Is LE-607 from Honda or is it an aftermarket fluid?
Old Jul 11, 2004 | 12:38 PM
Driv300mph's Avatar
Its aftermarket...
"Lubrication Engineers"
Old Jul 11, 2004 | 09:27 PM
Ludedude's Avatar
Administrator
Originally Posted by Driv300mph,Jul 11 2004, 01:38 PM
Its aftermarket...
And it's not for the transmission.
Old Jul 11, 2004 | 10:05 PM
Driv300mph's Avatar
I know, I said it was differential...
Old Jul 12, 2004 | 03:39 AM
Boston Duce's Avatar
At 30k you should probably do a clutch bleed also.
As far as different tranny oil, I just change to Syncromesh FM (GM product) and it is much smoother over a wider temperature range than the Honda OEM.
YMMV
Regards,
BD
Old Jul 12, 2004 | 03:42 AM
Popeye's Avatar
I've used Redline MTL since 5k and did clutch bleed too and the difference is amazing
Old Jul 12, 2004 | 05:01 AM
sweetj's Avatar
Are there any other conditioners that need to be added to the fluid?
Old Jul 12, 2004 | 05:28 AM
joe_s2k's Avatar
Note: The OIL JOURNALS! Everything you wanted to know about oil but were afraid to ask!
Check the "Under The Hood" section for much more info.
