Tranny Problem/Question
my car is almost opposite.. I Have noticed that I can slide OUT of GEAR from 3rd and 2nd, and almost into gear without pushing on the cluth pedal... i believe this is covered under TSB 54 and 55, but I have to get my other problems with the car straightened out first
I am getting my entire Tranny replaced it is at the dealership i went today to check on it and the tranny is sitting on the service bay kinda kool got to see the inside.. The second gear grind that was not fixed correctly caused all the syncros to go out i looked at the gears and some of the teeth were missing and one of the actual gears was damaged so they are rebuilding it all Free.. oh and i got a new clutch..
An example: My truck (which just got done towing the S2000 3000mi) had a leak at the clutch slave cylinder at 300,000 mi!! well the fluid would get low and you couldnt disengage the clutch . . . so you have to replace the slave cylinder and bleed the clutch fluid(Dot 3/4 brake fluid) and you should be set.
I dont think it should be leaking so soon but anything is possible.
pwr2al4
Jul 14, 2015 09:21 PM
cyber_x
Jan 16, 2004 01:21 PM
