TSBs and Recall List?
Old Apr 11, 2006 | 08:32 PM
mc2's Avatar
mc2
Default TSBs and Recall List?
Is there a list somehwere of all TSBs and Recalls applicable to MY 03?
I still have 5 months left under warranty and would like to get all that stuff done before its up.
Thanks.
Old Apr 11, 2006 | 08:52 PM
S2kracka's Avatar
Here is the complete list of '03 TSB's, unless you are experiencing the issue there is nothing the dealership can do for you. There are no recalls for the '03.
1. POWER TRAIN:MANUAL TRANSMISSION
2. ENGINE AND ENGINE COOLING:ENGINE
3. POWER TRAIN:MANUAL TRANSMISSION
4. ENGINE AND ENGINE COOLING:ENGINE
5. SUSPENSION:FRONT:WHEEL BEARING
6. POWER TRAIN:AXLE ASSEMBLY
7. ENGINE AND ENGINE COOLING:ENGINE
8. EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
9. EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC.
10. EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
11. SUSPENSION:FRONT:CONTROL ARM
12. VISIBILITY:WINDSHIELD
13. STRUCTURE:BODY
14. ELECTRICAL SYSTEM
15. STRUCTURE
16. EQUIPMENT
17. AIR BAGS
18. ENGINE AND ENGINE COOLING:ENGINE
19. EQUIPMENT:ELECTRICAL:ANTI-THEFT DEVICES
20. ELECTRICAL SYSTEM
21. ELECTRICAL SYSTEM
22. EXTERIOR LIGHTING:HEADLIGHTS
23. SERVICE BRAKES, HYDRAULIC:ANTILOCK
24. POWER TRAIN
25. POWER TRAIN:MANUAL TRANSMISSION
26. FUEL SYSTEM, OTHER
27. POWER TRAIN:CLUTCH ASSEMBLY:PEDAL/LINKAGE
28. OTHER
29. ENGINE AND ENGINE COOLING:COOLING SYSTEM
30. EQUIPMENT:ELECTRICAL:AIR CONDITIONER
31. POWER TRAIN:MANUAL TRANSMISSION
32. SERVICE BRAKES, HYDRAULIC:FLUID
33. POWER TRAIN:CLUTCH ASSEMBLY
34. ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL
35. VISIBILITY:POWER WINDOW DEVICES AND CONTROLS
36. STRUCTURE:BODY:ROOF AND PILLARS
37. POWER TRAIN:MANUAL TRANSMISSION
38. ENGINE AND ENGINE COOLING:ENGINE
39. AIR BAGS
40. STRUCTURE
41. OTHER
42. FUEL SYSTEM, OTHER
43. AIR BAGS
44. POWER TRAIN
45. POWER TRAINRIVELINEIFFERENTIAL UNIT
46. EQUIPMENT:ELECTRICAL
47. AIR BAGS
48. SERVICE BRAKES, HYDRAULIC:ANTILOCK
49. SERVICE BRAKES, HYDRAULIC:ANTILOCK
50. TIRES
51. SERVICE BRAKES, HYDRAULIC:ANTILOCK
52. POWER TRAIN:MANUAL TRANSMISSION
53. POWER TRAIN:MANUAL TRANSMISSION
Component Description:
Bulletin Number: 1205
Bulletin Date: DEC 2005
Vehicle: 2003 Honda S2000
Summary:
TRANSMISSION GRINDS AT SHIFTS, SKIP SHIFTING. ( NHTSA ITEM NUMBER - 10018868 )
Bulletin Number: 09012005
Bulletin Date: SEP 2005
Summary:
ENGINE OIL COOLER CENTER BOLT TORQUE SPEC. ( NHTSA ITEM NUMBER - 10018471 )
Bulletin Number: 01100
Bulletin Date: MAY 2005
Summary:
TRANSMISSION POPPING OUT OF FOURTH GEAR. ( NHTSA ITEM NUMBER - 627286 )
Bulletin Number: 04012005
Bulletin Date: APR 2005
Summary:
ENGINE FALTERS, NO POWER, WON'T REV OVER 7,000 RPM. HONDA SERVICENEWS. ( NHTSA ITEM NUMBER - 10016342 )
Bulletin Number: 01012005
Bulletin Date: JAN 2005
Summary:
CREAK OF GRUNT FROM REAR OF VEHICLE AT LOW SPEEDS. ( NHTSA ITEM NUMBER - 10014737 )
Bulletin Number: 1204
Bulletin Date: DEC 2004
Summary:
REAR AXLE CREAK OR GRUNT NOISE AT LOW SPEEDS. ( NHTSA ITEM NUMBER - 10018085 )
Bulletin Number: 04073
Summary:
INTERMITTENT HESITATION DURING HARD ACCELERATION. ( NHTSA ITEM NUMBER - 10017042 )
Bulletin Number: 10162004
Bulletin Date: OCT 2004
Summary:
HEADREST SPEAKER INSTALLATION. ( NHTSA ITEM NUMBER - 10014479 )
Summary:
XM RADIO ERROR MESSAGES. ( NHTSA ITEM NUMBER - 10014480 )
Bulletin Number: 09162004
Bulletin Date: SEP 2004
Summary:
SENDING HDS SNAPSHOT. ( NHTSA ITEM NUMBER - 10013833 )
Bulletin Number: 09012004
Summary:
POPPING SOUND FROM UPPER CONTROL ARM MOUNT. ( NHTSA ITEM NUMBER - 10013339 )
Bulletin Number: 00064
Bulletin Date: AUG 2004
Summary:
CONCERNS WITH WARPED OR DEFORMED WINDSHIELD MOLDING. ( NHTSA ITEM NUMBER - 10003052 )
13. STRUCTURE:BODY
Bulletin Number: 804
Summary:
POP NOISE AT FRONT UPPER CONTROL ARM MOUNT. ( NHTSA ITEM NUMBER - 10014057 )
Bulletin Number: 704
Bulletin Date: JUL 2004
Summary:
POOR RADIO RECEPTION, SEEK-STOP TEST. ( NHTSA ITEM NUMBER - 10014106 )
15. STRUCTURE
Bulletin Number: 03014
Bulletin Date: JUN 2004
Summary:
THE CONVERTIBLE TOP COVER IS BROKEN. ( NHTSA ITEM NUMBER - 10001233 )
16. EQUIPMENT
Bulletin Number: 05012004
Bulletin Date: MAY 2004
Summary:
AUDIO UNIT AND NAVIGATION SYSTEM ANTI-THEFT CODES AVAILABLE ON INTERACTIVE NETWORK. ( NHTSA ITEM NUMBER - 10013953 )
17. AIR BAGS
Bulletin Number: 04012004
Bulletin Date: APR 2004
Summary:
SRS INDICATOR ON AFTER BODY SHOP REPAIR. CHECK FOR SRS DIAGNOSTIC TROUBLE CODES. HONDA SERVICENEWS. APRIL 2004. ( NHTSA ITEM NUMBER - 10009018 )
Summary:
S2000 ENGINE, REPLACEMENT PART NUMBERS. HONDA. SERVICENEWS. APRIL 2004. ( NHTSA ITEM NUMBER - 10009026 )
Bulletin Number: 404
Summary:
AUDIO, ANTI-THEFT CODES. HONDA. TECH LINE SUMMARY. ( NHTSA ITEM NUMBER - 10009048 )
Bulletin Number: 02012004
Bulletin Date: FEB 2004
Summary:
CLEAN MODULATOR PUMP MOTOR GROUND FOR DIAGNOSTIC TROUBLE CODE 51/53. HONDA. SERVICENEWS. ( NHTSA ITEM NUMBER - 10009144 )
Summary:
SPEEDO/ODO READ EXCESSIVE SPEED AND DISTANCE. HONDA. SERVICENEWS. ( NHTSA ITEM NUMBER - 10009140 )
Summary:
MINIMIZE WARRANTY CLAIMS FOR HEADLIGHT ADJUSTMENT. HONDA. SERVICENEWS. ( NHTSA ITEM NUMBER - 10009143 )
Bulletin Number: 204
Summary:
GRUNT NOISE AFTER SITTING FOR SEVERAL HOURS. ( NHTSA ITEM NUMBER - 10014232 )
24. POWER TRAIN
Summary:
GRINDS AT UPSHIFT WHEN COLD. ( NHTSA ITEM NUMBER - 10014228 )
Summary:
2ND TO 5TH OR 3RD TO 5TH GEAR UPSHIFT. ( NHTSA ITEM NUMBER - 10014230 )
Bulletin Number: 04002
Summary:
FUEL FILL CAP BINDS AND POSSIBLE MALFUNCTION INDICATOR LAMP COMES ON WITH DIAGNOSTIC TROUBLE CODE P1456. THIS BULLETIN SUPERSEDES 04-002, DATED 02/30/04. ( NHTSA ITEM NUMBER - 10011094 )
Summary:
CLUTCH PEDAL IS NOISY OR FEELS NOTCHY. HONDA SERVICENEWS. ( NHTSA ITEM NUMBER - 10009133 )
28. OTHER
Summary:
HONDA DIAGNOSTIC SYSTEM LOCKED, NEEDS IMMOBILIZER RELEASE PASSWORD. ( NHTSA ITEM NUMBER - 10014220 )
Bulletin Number: 11012003
Bulletin Date: NOV 2003
Summary:
HEATER BLOWER MOTOR GETS HOT OR BLOWS A FUSE. HONDA. SERVICENEWS. ( NHTSA ITEM NUMBER - 10009278 )
Bulletin Number: 1003
Bulletin Date: OCT 2003
Summary:
HEATER BLOWER MOTOR OVERHEATS OR BLOWS FUSE. VARIOUS MODELS INCLUDING THE 2004 INSIGHT AND S2000. ( NHTSA ITEM NUMBER - 10004956 )
Summary:
MANUAL TRANSMISSION HARD TO SHIFT INTO 1ST GEAR, GRINDS INTO REVERSE. HONDA SERVICENEWS. ( NHTSA ITEM NUMBER - 10004970 )
Summary:
TESTING BRAKE FLUID FOR PETROLEUM CONTAMINATION. THIS INCLUDES 2004 INSIGHT AND S2000. ( NHTSA ITEM NUMBER - 10004955 )
Bulletin Number: 903
Bulletin Date: SEP 2003
Summary:
HARD TO ENGAGE 1ST GEAR, GRINDS INTO REVERSE. TECH LINE SUMMARY. ( NHTSA ITEM NUMBER - 10005021 )
Bulletin Number: 060103
Bulletin Date: JUN 2003
Summary:
VEHICLE'S EMISSION TYPE. ( NHTSA ITEM NUMBER - 10002701 )
Bulletin Number: 01008
Bulletin Date: APR 2003
Summary:
WHEN THE TOP IS LOWERED OR RAISED, OR THE DRIVER TRIES TO USE THE AUTO DOWN FUNCTION FOR THE POWER WINDOW, THE WINDOW GOES DOWN ONLY 3 OR 4 INCHES. THE WINDOW GOES DOWN ALL THE WAY IF YOU PUSH AND HOLD THE POWER WINDOW SWITCH. ( NHTSA ITEM NUMBER - 10001550 )
Bulletin Number: 03023
Summary:
CONVERTIBLE TOP CREAKS, POPS, OR RATTLES WHILE DRIVING OVER ROUGH ROADS. THIS NOISE IS ONLY NOTICEABLE WITH THE TOP RAISED AND THE DRIVER'S AND PASSENGER'S WINDOWS CLOSED. ( NHTSA ITEM NUMBER - 10001559 )
Bulletin Number: 040103
Summary:
DIAGNOSTIC TROUBLE CODES P0133 AND P0420 SET AFTER MANUAL TRANSMISSION REMOVAL AND REPLACEMENT. ( NHTSA ITEM NUMBER - 10003134 )
Bulletin Number: 303
Bulletin Date: MAR 2003
Summary:
P0133 AND P0420 AFTER TRANSMISSION R&R. ( NHTSA ITEM NUMBER - 10001829 )
39. AIR BAGS
Bulletin Number: 020103
Bulletin Date: FEB 2003
Summary:
SRS INDICATOR ON WITH NO SRS DIAGNOSTIC TROUBLE CODES (DTC) SET. ( NHTSA ITEM NUMBER - 10001811 )
40. STRUCTURE
Bulletin Number: 03012
Summary:
THE CENTER CONSOLE LIFTS UP IN THE BACK. ( NHTSA ITEM NUMBER - 10001231 )
41. OTHER
Bulletin Number: 010103
Bulletin Date: JAN 2003
Summary:
SEARCHING ISIS FOR DIAGNOSTIC TROUBLE CODE INFORMATION. ( NHTSA ITEM NUMBER - 10001793 )
Bulletin Number: 03001
Summary:
MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P1457 - EVAP BYPASS SOLENOID VALVE FAILURE. ( NHTSA ITEM NUMBER - 10000993 )
43. AIR BAGS
Bulletin Number: 120102
Bulletin Date: DEC 2002
Summary:
SRS INDICATOR COMES ON AFTER BODY SHOP REPAIR. ( NHTSA ITEM NUMBER - 10001976 )
44. POWER TRAIN
Summary:
USING THE RIGHT DIFFERENTIAL OIL. ( NHTSA ITEM NUMBER - 10001971 )
Bulletin Number: 1102
Bulletin Date: NOV 2002
Summary:
DIFFERENTIAL OIL RECOMMENDATION. HONDA TECH LINE SUMMARY. ( NHTSA ITEM NUMBER - 10013762 )
Summary:
ODOMETER ACCURACY. HONDA TECH LINE SUMMARY. ( NHTSA ITEM NUMBER - 10013805 )
47. AIR BAGS
Summary:
SRS WARNING ON AFTER BODY SHOP REPAIR. HONDA TECH LINE SUMMARY. ( NHTSA ITEM NUMBER - 10013808 )
Summary:
ANTI-LOCK BRAKING SYSTEM (ABS) OR TCS DIAGNOSTIC TROUBLE CODE (DTC) 51 AND/OR 53 TROUBLESHOOTING. HONDA TECH LINE SUMMARY. ( NHTSA ITEM NUMBER - 10013779 )
Bulletin Number: 110102
Summary:
ANTI-LOCK BRAKE SYSTEM (ABS) GRUNTS WHEN DOING A SELF-CHECK. ( NHTSA ITEM NUMBER - 10005871 )
50. TIRES
Bulletin Number: 100102
Bulletin Date: OCT 2002
Summary:
NEVER ROTATE TIRES. HONDA SERVICENEWS. ( NHTSA ITEM NUMBER - 10005918 )
Bulletin Number: 1002
Summary:
GRUNT NOISE WHEN ACCELERATING AFTER SITTING. HONDA OCTOBER TECH LINE INFORMATION. 2002 PRELUDE ALSO INCLUDED. ( NHTSA ITEM NUMBER - 10005927 )
Bulletin Number: 010902
Bulletin Date: SEP 2002
Summary:
CUSTOMER COMPLAINS OF MANUAL TRANSMISSION GROWLING NOISE WHEN ACCELERATING AT 2000 RPM. ( NHTSA ITEM NUMBER - 638111 )
Bulletin Number: 107
Bulletin Date: JUL 2002
Summary:
SUBJECT REGARDING TRANSMISSION GROWLING NOISE WHEN ACCELERATING AT 2,000 RPM. ( NHTSA ITEM NUMBER - 637657 )
Old Apr 11, 2006 | 10:38 PM
mc2's Avatar
mc2
Awesome, thank you so much.
I've only had the car for a few days and hvae not had to drive it much. i just wanted to see what issues i might look out for.
Thanks again.
cristiano1911
Apr 5, 2011 06:09 PM
wingnutLP
Car Talk - Non S2000
Apr 23, 2007 03:38 PM
S2000AD
Apr 4, 2004 10:35 AM
