Two things I really need help on.
Old May 5, 2010 | 04:17 AM
rlind's Avatar
Default Two things I really need help on.
Hi, I have a 2003 s2000 with 35k on it. I have a click sound when i accelerate from a stop from the passenger rear tire. Could this be a CV joints with a car that only has 35k? I also have a vibration when i go over 75mph like my tires are not balanced. The front tires are brand new. Thanks for any help you can provide!
Old May 5, 2010 | 04:33 AM
kaissi's Avatar
Try to balance all the tires first, that's the easiest problem to eliminate. If that did not solve the vibration, it's most likely CV Joints. And yes it can be a CV at 35k. I think it's the weakest link in the S2000 drivetrain.
The 2004 and up S2000 has CDV which usually delays clutch engagement when there is no tire spin and too much load is delivered to the flywheel. And thus diff and CVs last a little longer.
Old May 5, 2010 | 04:45 AM
TPhong's Avatar
The clicking could be a number of things. Do a search for the Rear Axle Nut and see if your symptoms sound like anyone else's.
Old May 5, 2010 | 05:11 AM
rlind's Avatar
Thank you both for you help!
Old May 5, 2010 | 12:09 PM
starchland's Avatar
let us know what happens
Old May 5, 2010 | 05:52 PM
Jspd's Avatar
had a nasty vibration on my02 and balanced the tires, redid alignment, and swapped the CV cups but the vibration was still there. sat down tonight and swapped out my old axles for new ones in 1.5 hrs and smooth as silk again!
good luck with that, but i would put money on the CV's.......just my .02
Old May 6, 2010 | 03:05 AM
starchland's Avatar
what kind of axles? reman, oem honda?
FlyNavy
Mar 14, 2011 09:22 AM
apxking
Sep 3, 2009 05:29 PM
lychyrychy
Sep 29, 2008 09:04 AM
xxlap1xx
Jun 14, 2007 01:33 PM
B SweepeR B6
Oct 18, 2005 01:23 PM
