The ultimate Electric Supercharger.
I was reading another post earlier and it sparked my intrest to post this link to see what conversation we could stir up. Post your thoughts after reading the article. Electric supercharger article.
Almost the opposite of a hybrid.
Not sure what you're expecting for feedback frofro... This kind of thing almost certainly is inferior to a mehanically driven supercharger. Especially since the aftermarket for such parts exists for S2000s.
https://www.s2ki.com/forums/index.php?showt...0&#entry2973673
https://www.s2ki.com/forums/index.php?showt...0&#entry7013193
https://www.s2ki.com/forums/index.php?showt...0&#entry5480246
https://www.s2ki.com/forums/index.php?showt...0&#entry4333908
http://forums.s2ki.com/forums/index.php?showtopic=186847
https://www.s2ki.com/forums/index.php?showt...0&#entry7015887
https://www.s2ki.com/forums/index.php?showt...=0&#entry186631
https://www.s2ki.com/forums/index.php?showt...0&#entry7290811
https://www.s2ki.com/forums/index.php?showt...=0&#entry915397
https://www.s2ki.com/forums/index.php?showt...0&#entry4925670
https://www.s2ki.com/forums/index.php?showt...0&#entry5492895
https://www.s2ki.com/forums/index.php?showt...0&#entry6126822
There's a company making a real electric supercharger. Requires it's own battery packs and uses 3 starter motors to turn over what looks like a roots type supercharger. They tested it, it works like No2, you get a boost, then the batterys need to be recharged for the next pass/run or whatever.
I'm not sure why they built it but, it did work.
[I'll ignore this particular product and talk about the concept in general.]
There are some definite advantages in using an electric supercharger and some disadvantages, too. Whether it should be used or not depends on how these balance out.
Advantages:
It is independent of RPM! You can tune the pressure boost to anything you like. You don't have to worry about wasting boost via blow-off valves or dealing with no boost at mid-to-low RPMs.
You can package it anywhere you want. The supercharger does not have to be placed in line with the crank pulley.
Disadvantages:
You have to convert (with losses) the mechanical energy of the engine into electrical energy, transmit it (with losses) through cables, and convert it (with losses) back to mechanical energy in the supercharger.
You also need an electric motor, which is heavy.
The bottom line:
In the future, cars will have much higher voltage electrical systems, which will allow things like an electrical supercharger to be efficient enough to buy their way onto the car. But at 12V, it's just not practical.
Advantages:
Disadvantages:
The bottom line:
