Understeer?
I think the OP is confusing a car's bias toward understeer or oversteer. With actual over/under-steer. Most cars can be made to do either with the wrong inputs. And this bias can be adjusted. The AP1 came fairly neutral from the factory, thus it is easier to get into oversteer.
Most (average) drivers would prefer an understeer bias, over a neutral bias, or oversteer bias, because understeer is a lot easier to correct than oversteer.
Based on this preference, the AP2 was changed to have a mild understeer bias. The MY08 may have even more bias towards understeer than 04-07, but time will tell.
As others said, the easiest things to do would be to add a bigger front sway bar (I just put on the Gendron bar and it makes a world of difference, though its a little expensive for just driving around on the street) and do some autocrosses/take an Evolution school. Seat time is 1000 times more important than adding parts to the car though.
Originally Posted by mikegarrison,Sep 28 2007, 09:58 AM
'zactly. With a turn in under hard braking I'm a lot more likely to loop it than to understeer.
Are you running any kind of wing?
Originally Posted by Spec_Ops2087,Sep 28 2007, 10:34 AM
I get some understeer at autox's when I brake late in a sharp turn...front end just plows forward.
I autocross on S02's, so if you're running R compound tires your situation may well be quite different, but if you are threshold breaking right up to turn-in, and then transitioning to trailing brake, only to be greeted with massive understeer, you may just need to alter your timing a little. During threshold breaking in a straight line there is so much weight being transferred to the front tires that they're on the verge of overloading and sliding. Any turn-in at all will start them sliding, becuase you're already using all the available grip. Start your breaking just a little sooner, then ease off a little just *before* you turn-in. Once you start turning in and breaking at the same time and still have grip, it's easier to balance the two forces as you continue to turn in. It helps to do the same kind of thing when getting back on the throttle at corner exit. If you start unwinding the steering just a bit before you start applying throttle, and get into power-on cornering smoothly, it's easier to balance the forces through the rest of the corner. Just allow a little more time at the transition points that are causing problems. ("To go fast, you have to know when to go slow."
) With practice you may find that you can leave less time between the initiation of steering and throttle/brake inputs, but you have to get it right before you can practice doing it right.
NOTE: We are talking about autocrossing here, not techniques for the street. Threashold breaking followed by heavy trail breaking is not something you normally want to be doing on the streets, because sooner or later you WILL make a mistake, and it's rarely pretty.
Originally Posted by RED MX5,Sep 28 2007, 06:23 AM
OK, now that I know a little more about your situation, I can tell you exactly what you need to do about the car's oversteer. The fix is cheaper than changing the cars handling, and a heck of a lot more fun. Go to an Evolution Phase 1 school. You'll have a blast, and by the end of the day you will have cut several seconds off your times and will be far more comfortable with the cars handling. I'll bet that if you go to an Evolution School and a few autocrosses, you will no longer want to change the cars handling. It's easy to get the impression that the early cars have too much oversteer, becaue (as you have discovered) they will bite you if you screw up, but when they're driven well, the handling is almost dead neutral. If you learn to manage it, you'll learn to love it.
