Unknown clunk in reverse this morning
Old Jul 16, 2001 | 07:06 AM
legalrep's Avatar
Default Unknown clunk in reverse this morning
This morning when I put car in reverse and started to release clutch to back out of my garage, a loud clunk came out of rear of vehicle somewhere. This happened once before. Car drove normal, no repeat. Has this happened to anyone else and is it something I should be concerned with, and is there something I should have checked? My first thought is the differential. I have 16000 miles. Should I have fluid changed, and if so will putting Mobil 1 dif. fluid or whatever the synthetic is called void the warranty?
Old Jul 16, 2001 | 07:09 AM
cdelena's Avatar
Asked and answered dozens of times. You probably washed it before parking it. The brake pads stick when allowed to dry with the parking brake on. Thus the bang when they release.
Old Jul 16, 2001 | 07:15 AM
legalrep's Avatar
Didn't wash it but had brought it in from a heavy rain. Thanks for easing my mind.
Old Nov 14, 2002 | 04:00 AM
cerberus264's Avatar
If it only does it the once, then its probably just the pads sticking. If you can then repeat it by going into 1st and forward, then reverse and back ...and if it happens again you have another problem. If you can repeat it there are loads of posts about this if you do a search on 'Clunk' or 'Drive'. It could then be to do with your CV joint cup.
Old Nov 14, 2002 | 08:54 PM
honda9krpm's Avatar
Thanks guys.....I had the same prob
Now no more palpitation in the morning
Gotpepsi
Mar 21, 2015 05:57 PM
AndyThomason
May 29, 2007 01:58 AM
minh
Nov 3, 2006 11:54 PM
way2low01
Oct 15, 2006 09:15 PM
S2000_rider
Mar 10, 2004 09:22 AM
