used s/c s2k, 2003
Old Jul 8, 2005 | 10:58 AM
hksupersi's Avatar
Default used s/c s2k, 2003
how reliable is it buying a used s/c s2k, 2003. with around 14k miles. anything i should check for and worry about. should i check stuff like detonation, or does s/c don't cause detonaiton.thanks.
Old Jul 8, 2005 | 11:33 AM
S2000RAT's Avatar
Should be reliable. I would check for a slipping clutch if it is stock. Also free play in the axels.
Rich
Old Jul 8, 2005 | 02:33 PM
hksupersi's Avatar
how would the slip clutch feel and free axles feel. thanks.
Old Jul 8, 2005 | 04:05 PM
Silver_S2000's Avatar
You will deffinently be able to tell if the clutch is slipping...Whenever you shift gears the RPMs will jump up and slowly go back down to where they are supposed to be...Also if you just gun it the RPMs will jump up and slowly go back down "slip"...not a good thing...as for axel play..The only thing I could think of that would be able to determine it is the sound it would make when you are taking off from a dead stop...A "clink" or something similar...I think the purchase would be a good investment...It'll save you 5k in the long run ...Wish my 02 came sced
Old Jul 10, 2005 | 08:27 AM
hksupersi's Avatar
thanks. i'll be checking the car out this week or so. thanks again.
Old Jul 11, 2005 | 04:11 AM
S2000RAT's Avatar
You can feel the axels shake when you are on the gas hard. Or turning on the gas hard it feels like a wheel weight is missing.
ron1999
Jan 28, 2022 05:39 AM
Simon B
May 23, 2016 12:07 PM
ozzykhan16
Jun 9, 2010 11:54 AM
bakalag
Feb 12, 2010 11:24 AM
andym_UK
Aug 22, 2005 10:41 AM
