valve adjustment
Old Jul 30, 2005 | 06:07 PM
lamvu's Avatar
Default valve adjustment
I'm doing a valve adjustment at the moment. I have a quick question. It is really hard to determine when enough 'minimal drag' is necessary. So my question is this, Would it be ok to be able to stick .010 into the exhaust side and .011 not into the gap? Would this be a good measure to go by? and the same logic with the intake, .008 goes in and .009 dosen't.
I hope this makes sense??
Another question, is it ok to tighten the valves too much? what is the result of this? and what if you drive w/ loose vavles? what would the result of that be?
thanks in advance.
Old Jul 30, 2005 | 08:30 PM
oakfloor's Avatar
thanks in advance.
There is a good thread here on valve adjustments. check it out
Old Jul 30, 2005 | 09:50 PM
lamvu's Avatar
I've searched and the only thing that comes up is a how to... but it dosen't really say, exactly a 'slight drag'
Old Jul 30, 2005 | 09:51 PM
mad-dog-one's Avatar
thanks in advance.
Too tight keeps the valve from fully closing and is unacceptable. A valve that doesn't fully seat will overheat. A little loose is noisy but OK. Within limits, a loose valve is a happy valve.
Old Jul 31, 2005 | 03:28 PM
lamvu's Avatar
Ok, i just finished my valve adjustment. When I rev the car I hear a slight tick... it is a small noise, but if you do a valve adjustment would there be any valves noise? or is small valve noise normal?
-also, Can you tell if you have over tightened a valve? Would that make a sound simliar to loose valves?
Old Aug 1, 2005 | 09:42 PM
lamvu's Avatar
ttt
Old Aug 2, 2005 | 03:57 AM
Silver_S2000's Avatar
I...dunno
Old Aug 2, 2005 | 04:26 AM
Pillowsplat's Avatar
I got this suggestion off of the Honda VFR board for adjusting valves.
"It should feel like putting the feeler gauge in the middle of a thick book of yellow pages" " Light drag"
trich101
Apr 15, 2011 09:54 PM
03BlkS2k
Mar 22, 2009 04:53 PM
chillout18
May 9, 2008 08:03 PM
F20C1
Feb 23, 2004 08:15 PM
