vented hood and underhood temps, etc.
Old Jun 8, 2007 | 06:22 PM
nightcrawler7188's Avatar
Default vented hood and underhood temps, etc.
have you guys running vented hoods noticed a decrease in hot weather bogging? i'm thinking it'll reduce my underhood temps and decrease the hot weather bogging i experienced after installing my FIPK, but am i wrong?
also do you have to be careful with a vented hood in the rain or anything like that? or do you guys just drive it like normal? i'm thinking i shouldn't have to worry about anything because some cars come with OEM vented hoods, but just making sure.
also, what is the ratio of CF hoods installed: CF hoods fading/yellowing/whatever?
TIA.
Old Jun 8, 2007 | 07:10 PM
Kodokan_4's Avatar
The vented hood made a HUGE difference in engine compartment temp on hot days!
Your results will vary depending on the intake/hood combo you choose.
There is no way water will flow through the (Amuse style) hood vent into my (PRM) intake because the velocity stack is not directly under the vent.
A constant stream of heated air (heat waves) is visible coming out through the vent on hot days.
I have zero heat bogging, and sharply increrased throttle response.
-Pete
Old Jun 8, 2007 | 07:14 PM
those tires look monstrous.
is the intake the only thing under the hood i'd have to worry about water getting on? what about the battery/other electrical stuff?
from what it looks like, an MG style hood shouldn't let water get on the filter of my FIPK right?
Old Jun 9, 2007 | 02:42 PM
gomarlins3's Avatar
I have been thinking about one to stop my belt squeal at 8,000 RPM's on the SC. I just worry about how they fit and align. I have seen a few CF hoods that just don't line up correctly.
Old Jun 9, 2007 | 07:56 PM
wildcardtrd's Avatar
I've logged some serious street time on my AEM EMS, and I've noticed significant drops in under hood temps with the hood vents. As far as rain, you get a great deal of water up under the hood from the airflow under the car...I have my ITB's positioned just under and inside my hood vents, and I've noticed zero weather related issues.
FYI, with hood vents, I've noticed my IAT's hover between 8 and 10 degrees above ambient while cruising on the highway, and sit about 30 above ambient in total stop and go traffic. That is great improvement over stock, where IAT's would creep up to almost 70 degrees above ambient on a hot summer sitting in traffic.
Old Jun 9, 2007 | 08:02 PM
s2kSEOUL's Avatar
I've had the MG style Seibon for about a year now. No yellowing. Fitment is not bad, but not perfect.
Weather doesn't seem to affect anything underhood. I added the F5 fujita CAI at the same time so I have a combination of heat bog fixes going on at the same time.
When sitting still you can see the heat rise out of the vents --> SUPACOOL!
Old Jun 9, 2007 | 08:20 PM
viets2k's Avatar
Vent hood does makes alot of different when it come to heat-soak. I don't drive my S in the rain so i don't really know how the rain come in play. Best way to find out is to wash your S.
Oh-yeah...i like how the heat rise out of the vents too when sitting at the lights.
Old Jun 10, 2007 | 07:00 AM
thanks, this thread has actually been helpful!
one final question: anyone running an MG or TS style CF hood with the K&N FIPK? i want to make sure that it won't let water on to my filter.
Old Jun 11, 2007 | 03:55 AM
s2kSEOUL's Avatar
Well, from what I understand as long as the filter is not totally submerged you will be fine. My friend's jeep has the k&n and the filter just sits uncovered in the engine bay and gets all kinds of crud on it just from regular driving and it seems fine.
My Fujita sits right in front of the passenger side tire in the bumper and stays pretty clean.
DemiSlayer
May 21, 2018 11:14 PM
yellows2k_1226
Jan 9, 2008 01:38 PM
icecreamballer
May 17, 2006 04:33 PM
ayelien
Feb 4, 2004 04:07 PM
lupin
Sep 4, 2001 03:04 AM
