Very strange problem with my S2000...
Old Feb 11, 2002 | 07:07 PM
Red_s2k's Avatar
Default Very strange problem with my S2000...
The remote will not work in any way, form, or fashion. It worked when I got in it satuday... when I arrived 30 miles later, it would not lock the car or open the trunk. the light comes on, on the remote (actually both remotes) but nothing happens. At 1st I thought it was the valet button, but I thought if it was on it would light the light. Any ideas?
Old Feb 11, 2002 | 07:10 PM
yellow2001's Avatar
batteries may be low?
Old Feb 11, 2002 | 07:11 PM
Ldogdotcom's Avatar
Ummmmm... turn off the car?
Old Feb 11, 2002 | 07:15 PM
Red_s2k's Avatar
batteries replaced and the car was not running ... with the keys out.
moonpie's Avatar
press remote on left cheek, then press buttons seriously...
oh, are you sure you're not hitting the power sliding door button on your Odyssey remote? I do that at times
Old Feb 11, 2002 | 07:16 PM
Red_s2k's Avatar
right....
Old Feb 11, 2002 | 07:21 PM
nEVERCLEAR's Avatar
Two things I would check
The fuse for the doorlocks and if there is one for the keyless entry. I would check all fuses in case
I would check the location and condition of the recieving wire (antenna) along with any connections under the dash by the pedals.
Just a suggestion ...
Old Feb 11, 2002 | 07:41 PM
yellow2001's Avatar
[QUOTE]Originally posted by moonpie
[B]press remote on left cheek, then press buttons
Old Feb 11, 2002 | 07:58 PM
ricosuave's Avatar
try using your other supplied remote. if it works, something is wrong with the first remote.
Old Feb 11, 2002 | 09:55 PM
Maverick-Goose's Avatar
remember, honda remote sucks... you need to get real close to the car.
