VTEC engagement on 04? same?
Old Dec 2, 2004 | 09:34 AM
hondaboyS2000's Avatar
Default VTEC engagement on 04? same?
newbie question here
what is the VTEC switchover RPM on the 04's ??? is it the same as the pre 04's S2000?? i know i feel a noticeble sudden kick around 7k rpm+ somewhere there .. im just curious whats the exact RPM vtec engaement... thanks
peace.
Old Dec 2, 2004 | 10:54 AM
Cyclon36's Avatar
I'm pretty sure it's 6200 rpms, about 500 lower from the previous models.
Old Dec 2, 2004 | 10:59 AM
hpark's Avatar
peace.
~6K
Old Dec 2, 2004 | 11:10 AM
Elistan's Avatar
About 6000 (which is exactly the same as the previous ones.)
Where do you live? High altitudes can sometimes cause the switchover to migrate to a higher rpm.
Old Dec 2, 2004 | 11:13 AM
honda606's Avatar
It's ~ 6,000 for all model years. The 04-05's lost VTEC rpm's because of the lowering of the redline.
Old Dec 2, 2004 | 12:48 PM
Cyclon36's Avatar
I stand corrected. Thanks.
Old Dec 2, 2004 | 12:54 PM
Ooalloems2koO's Avatar
2000-2005 Vtec engaging at 6k unless u mess with VAFC
Old Apr 18, 2005 | 06:36 PM
S2Crazy's Avatar
I sold my MY00 about two years ago and purchased a MY05 last week. I took a road trip and just got done with the break-in period.
Question:
In my MY00, the 1-2 shift (if performed at redline) brought the revs back to ~6000 RPM, i.e. in the VTEC part of the powerband.
In my MY05, it seems that the 1-2 shift (also performed at redline)brings the revs back to ~5500, i.e. not in the VTEC part of the power band.
What's up with this? Is there really a "dead spot" in the power band between first and second gears?
Old Apr 18, 2005 | 07:07 PM
Warren J. Dew's Avatar
No. With the clutch delay valve, the clutch slips enough that you stay in VTEC.
Without the clutch delay valve, I understand the rear wheels slip enough that you stay in VTEC.
I believe, though, that the engine electronics have been changed so that if you are at part throttle, VTEC may not engage until a higher RPM, if at all.
Old Apr 18, 2005 | 07:10 PM
Elistan's Avatar
Shift just slow enough however, and yes you will encounter that "dead spot" before VTEC engages on the 1->2 shift.
