Want more VTEC!
Old Sep 27, 2006 | 10:16 AM
Dino Antonov's Avatar
Banned
or an ls7 like that solstice or however you spell it.
patastinky's Avatar
hook your vtec solinod to a switch - make sure it's getting 12v and it has a ground... when ever you feel the need for some massive VTECH powa!!! just flip the switch and you'll fly!!!!!! It's all the craze now.. Make sure the 3 prog switch that you use is from JAPAN. These switch work best while in VTEK and will hold VTAK longer then other conveitional switches!!
Old Sep 27, 2006 | 10:18 AM
Banned
are you serious?!
Old Sep 27, 2006 | 10:26 AM
S2kracka's Avatar
Originally Posted by Dino Antonov,Sep 27 2006, 12:18 PM
are you serious?!
Yes he is. Its a well known fact that JDM switchez hold VTAK power far longer than the knock-offs from the USA, China, Korea, etc. JDM makes the VTAK hit hard too, the switchover alone will spin the tires.
Old Sep 27, 2006 | 10:27 AM
SiCK HONDA's Avatar
Originally Posted by Dino Antonov,Sep 27 2006, 01:18 PM
are you serious?!
No, he's not serious...
On a serious note, if you want to spend MORE time in VTEC everyday, you should get yourself some gears...
Your top speed will decrease slightly, but you'll be higher in the rev range in every gear= more VTEC!
-Matt
Old Sep 27, 2006 | 10:32 AM
Banned
i've been contemplateing 4.77. not sure if i want to go that route though.
Old Sep 27, 2006 | 10:47 AM
Brandon25pdx's Avatar
hondata reflash
Old Sep 27, 2006 | 10:56 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
If you get gears,get the 5.13.
Old Sep 27, 2006 | 11:06 AM
DerrS2K's Avatar
Originally Posted by Brandon25pdx,Sep 27 2006, 02:47 PM
hondata reflash
His first mod would have to be an 06 or 07 AP2 before that would work.
Old Sep 27, 2006 | 11:36 AM
jelliotlevy's Avatar
Unless I am somewhat sadly mistaken, the point of crossover for the VTEC solenoid to engage is chosen to be around 5900 rpm, because at that point the power available from the high lift cam set exceeds the power available from the standard cam set. To engage VTEC at 4000 rpm, for example, should actually reduce performance since the high lift cam is not yet in its power zone. I think some S2000 owners have made small adjustments in that crossover rpm, and perhaps that has some subtle performance enhancing effect. But I have to believe that Honda engineers know how to set up the VTEC parameters.
And, let us not confuse VTEC with VTAC. VTEC is Honda's way of quickening our pulses. VTAC is short for ventricular tachycardia, which is an extremely bad, often lethal, way to quicken our pulses. VTAC is to be avoided at all costs. VTEC is to be sought out whenever the law and safety allow it.
