Water inside my headlights
Old Dec 3, 2005 | 09:35 AM
Formula's Avatar
Default Water inside my headlights
I noticed today after 1 year of no problems, there is some water inside my healdights between the clear lens and glass on top of it, will this just dry out? is it safe for the healdight?
Old Dec 3, 2005 | 10:49 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
One thing for sure,this is not normal.
Do you have cleared headlights???
Old Dec 3, 2005 | 11:13 AM
Saki GT's Avatar
How does the headlight assembly hold the bulb? Can you simply unplug the bulb from the back of the assembly? (I've never bothered looking)
Old Dec 3, 2005 | 11:43 AM
DaveOnLI's Avatar
From a quick look at the instructions for clearing headlights it indicates that there is a cover over the socket/ballast held by Torx screws.
Instructions on the Rick's web site:
http://www.ricks2k.com/info/install.php
Old Dec 3, 2005 | 12:02 PM
Stratocaster's Avatar
Yes, you really should remove the headlights from the car and remove all the bulbs and ballasts. This till open up the headlight so it can dry out. If you don't, the ballasts are mounted on the bottom, and if the water gets on the connections, you will blow them. They cost 300 each, so do it as soon as you can.
Also from you post, it sounds like the headlights have been cleared, if they have a clear lens over the turn signals, then they have. You will want to remove the silicon from around the clear cover and black backing, and reapply. then when you reinstall the bulbs and ballast, use some grease (for rubber seals) to the seals. That should take care of the problem for good.
good luck
Old Dec 3, 2005 | 12:03 PM
Tugz_S2K's Avatar
Banned
there is a required burn time for any fogging to burn off. I believe the dealers give it 15-30mins. If it does not burn off then there is a leak either the bulb seal or the hot melt that is used between the lens and housing.
Old Dec 3, 2005 | 09:54 PM
Saki GT's Avatar
I had a cracked headlamp once on another car, and if I noticed water in the assembly, I'd just pop out the light and let the engine heat evaporate the water build up. It was a quick way to dry out the light, just don't turn your lamps on if you leave the light plugged in...
Old Dec 3, 2005 | 10:10 PM
Nametaek3n's Avatar
I'm having the same problem too, on my left headlight on the lower corner near the amber diffuser. I have stock headlights with no clear diffusers. i just noticed it this evening, never happened before. sucks, strapped for cash and not much money to spend as of right now, should i go to Honda dealership and see if they can fix it or just try to do it myself. no tools as of right now, just moved and left everything back at parents house. any suggestions would be appreciated.
tom
Old Dec 5, 2005 | 08:37 AM
wil687's Avatar
If you want to dry them out without having to disassemble, try blow drying them by holding a blow drier close to the lens, it worked for me.
Saki GT
Jun 6, 2015 07:33 PM
akashanksta
Apr 18, 2013 10:16 AM
yuning83
Jun 21, 2009 09:30 AM
highrev
Aug 27, 2003 11:55 AM
