weight reduction
Old May 25, 2004 | 09:05 AM
gerryk's Avatar
Default weight reduction
I am contemplating the removal of my convertable top and motor mechanism to decrease weight for the track. How much does it all weigh and how hard is it to remove and to reinstall? I have an oem hard top to replace it with-- it weighs ~45lbs.
Old May 25, 2004 | 09:16 AM
RazorV3's Avatar
weighs about 40 pounds.
Old May 25, 2004 | 09:47 AM
Nishant's Avatar
they should just about cancel each other out so you'll be back to stock weight
Old May 25, 2004 | 11:00 AM
gerryk's Avatar
Are you sure about 40lbs? I thought I read it was more like 140lbs? wow sounds like it wont be worth the effort
Old May 25, 2004 | 01:02 PM
Saab9-3's Avatar
Well, it's a very small, thin, non-insulated top. The frame is not very large, and due to the small size and low weight of the top, the motor does not have to be very large.
Old May 25, 2004 | 01:04 PM
JL9000's Avatar
Replacing the entire soft-top assembly with the OEM hardtop should save you around 20lbs. However, take into account the aerodynamic benefits of the ht as well.
Old May 25, 2004 | 03:22 PM
djkojione's Avatar
the soft top, frame and motors weighs more than 45lbs.
Old May 25, 2004 | 03:23 PM
honda606's Avatar
This is correct but I think it's closer to 100 than 150.
Basically you will shed about fifty pounds with the hardtop and no softtop/motor.
Old May 25, 2004 | 08:44 PM
Ludedude's Avatar
Administrator
63 pounds for the softop and motors. 42 or 43 pounds for the factory hardtop, so the net saving is about 20 pounds. JL9000 already said it but there are aerodynamic benefits to the hardtop as well.
Old May 25, 2004 | 11:16 PM
krazik's Avatar
Administrator
Uhm no way. Softtop with motors is over 80lbs. Its really heavy. I don't remember the exact weith.
