Weight Shift on Throttle Lift?
First post here! Just picked up my 05' AP2 today(previous ND2 owner), and I noticed that on a very straight road, if I lift off of my throttle the body will roll to the right a bit. It's completely straight if I'm on the gas, but right when I lift off I find my steering wheel wanting to drift right a bit. Is this a problem with my alignment, or could it be some other underlying problem? I couldn't find another thread that was talking about this but if there is, I would greatly appreciate a link. Thanks!
I just wanna thank you and windhund, I feel so foolish for not even taking that into consideration. The car came off a transport truck from California (I had a friend test drive and inspect the car for me)to here in Seattle, and when I went to measure it they were 18 psi on the two left and 16 on the right ☠️. She drives perfectly after filling them all up to 32, thanks guys!
Anyway, I'm sure you'll notice if your tire loses pressure again. I just wanted to confirm that this is the only time I've had the problem of throttle steering.
... and not just a "spec alignment," but a UK Spec Alignment.
Not to hijack this thread, but the UK alignment performs much better than the US alignment.
I ran my AP1 from the day that I bought it new with the US alignment. After I got used to the car, I noticed bump-steer (particularly on the I-90 W to I-5 N ramp). Then I tried the UK alignment and it completely cured the bump-steer.
Note that the throttle steering caused by low tire pressure is completely separate from the bump-steer caused by alignment choice, but since both have been discussed here I wanted to point out the subtleties.
I observed this throttle steering appear on my AP1 a few years back. It was a drastic change. The OEM tires for the S2000 are run flats, and it turns out that I had a flat. It wasn't obvious because the sidewalls are so stiff. I filled the tire but the problem returned because there was a hole causing a leak.
