weird noise on startup?
Old Jul 8, 2005 | 11:06 AM
aronparsons's Avatar
Originally Posted by nalVle,Jul 7 2005, 04:10 PM
but this is the first time its ever happened.
-Chris
edit: also, i just picked up 2 quarts of oil, and put them in. i started the car, and it didnt make the noise. does this mean my car is burning oil? there's never any pools of liquid underneath my car.
You just put in 2 quarts of oil like that? You have other issues most likely if you were 2 quarts low.
My MY03 has the "baby spooling" noise when it first starts up as well.
Old Jul 8, 2005 | 11:11 AM
Nate03's Avatar
Is it a hissing sound or a fast ratcheting sound ?
The fast ratcheting sound is the timing chain tensioner. These seem to be failing prematurely in increasing numbers. Billman250 of the Metro NYC gang has noted & repaired this problem on several early -> late model S's...
Old Jul 8, 2005 | 02:24 PM
nalVle's Avatar
its a 'ratcheting sound'. it sounded like it would be something related to the timing chain. to the other post above, when i checked the oil it was at the L on the stick. when i added the two quarts it was just above the H. i got the oil changed today and they said there's no oil leak, so im going back in 1500 miles to get an 'oil consumption test' done. thanks for the replies.
-Chris
Old Jul 8, 2005 | 02:32 PM
Nate03's Avatar
definitely timing chain tensioner then - IIRC the part is approx $55 and you could check with Billman250 on how much he charges or what's appropriate if you have someone else do the replacement.
Possible DIY if you have moderate mechanical ability. I expect we'll have a tech day on long island some time before Fall Colors n- if you choose to hold out unitl then and would come to mineola you could have the TCT switched out then. Stop in on the metro NYC forum and inquire within.
Old Jul 9, 2005 | 12:25 PM
nalVle's Avatar
thanks a lot for your help.
-Chris
Old Jul 9, 2005 | 12:32 PM
S2Karizma's Avatar
My car has a hissing sound when I start it up, I'm sure this is normal right? I'm barely at 18K.
tags
Oct 19, 2011 09:38 AM
PaulF
Oct 29, 2009 12:30 AM
macdaddies911
Aug 1, 2009 07:41 PM
hellothere
Dec 16, 2004 03:10 PM
John MI blk/blk '01
Jun 23, 2001 02:06 PM
