What is the crush washer for?
Old Jan 22, 2004 | 11:53 PM
E36Ap1's Avatar
Default What is the crush washer for?
The first time I heard this when I went to go buy my oil filter at the Honda dealer. They ask me if I wanted to get a crush washer I was why and they said I dunno. But Honda said I should so I will. Just wondering why I should always put the crush washer. It doesn't actually crush.
Old Jan 23, 2004 | 12:58 AM
forsaken's Avatar
It helps seal the locknut to the oil pan, so there's no oil leak. Alway change the crushwasher when u remove your oil plug
Old Jan 23, 2004 | 03:20 AM
paul1948's Avatar
Actually, the crush washer does crush (and spread) a little; thereby making the seal. Use one. They're very cheap insurance.
Old Jan 23, 2004 | 08:08 AM
wanabe's Avatar
and some members of this board turn them around and reuse them... for the cost, i would just get a new one. but you definitely need one to properly seal the oil plug (bolt).
Old Jan 23, 2004 | 08:20 AM
so_weahd's Avatar
Yeah, they're cheap. Next time you buy some parts from HandA or HardTopGuy or any other dealer, add a six or ten washers (and why not a few for the diff and a couple for the tranny?). You'll spend maybe ten or twenty bucks and then be set for years to come. You may even look forward to using them!
Old Jan 23, 2004 | 08:23 AM
jeffbrig's Avatar
Actually, the 'crush' washer does crush. When you take off your old one, compare the face of it to the new one. A pic would be worth a million words, but you can see the heighth difference between the compressed and non-compressed areas of the washer.
Old Jan 23, 2004 | 08:28 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If re-used, it will crush a little each time. The dealer (a good one, anyway) will give you one for free when you buy the oil and filter from them. It can be re-used, to a point, untill it starts to distort. A new one each time is good peace of mind. I personally change mine every other oil change.
Old Jan 23, 2004 | 08:35 AM
Drunken_Monk's Avatar
I guess im going to ask if my dealer throws one in for me...
Old Jan 23, 2004 | 08:58 AM
Dark_Sub_Rosa's Avatar
everytime i go for my filter they stick a crush washer in for me, no biggie, but I always change mine at each oil change.
Old Jan 23, 2004 | 10:03 AM
DeluxeS2k's Avatar
I didn't put mine in on the last oil change. No problem so far, no leak
