What is double clutch
Old Feb 11, 2005 | 09:24 AM
slvrKCs2k's Avatar
Default What is double clutch
When I am accelerating or shifting from gear to gear in a competitive spirit I just pull my foot back from the clutch and put pressure on the gas when I get to the friction point. I feel as if I am loosing time and speed as I do this. Some times the car almost jerks forward (not violently) when I change gears. I see some people talk about double clutch and dropping the clutch when racing. What is it and is it bad for our cars?
Old Feb 11, 2005 | 09:56 AM
revhi's Avatar
Double clutching is when your not granny shifting.
The jerk motion is when your clutch is engaging. Learn to shift faster. Dropping the clutch just means revving it up and letting out the clutch as fast as possible.
Old Feb 11, 2005 | 10:23 AM
hpark's Avatar
i think you are not matching revs.....release the clutch when the RPM is too low or high for the next gear means a non-smooth shift every time.....it seems like from your description you are letting the revs drop too much for the next gear???
Old Feb 11, 2005 | 11:11 AM
seung's Avatar
you do it when you drag race, for that "10 sec" of your life.
Old Feb 11, 2005 | 11:41 AM
Saki GT's Avatar
From what I understand, double clutching is just what it sounds like - you press the clutch pedal in once to pull the car out of gear, then match revs for the new gear you want, then press the clutch pedal again to engage the drivetrain/engine again. You don't really need to double clutch anymore unless you have a clutch assembly with no synchros, and if you can heel&toe, you don't really need to double clutch either.
Old Feb 11, 2005 | 12:53 PM
Driv300mph's Avatar
Double clutching on sports cars is quite possibly the most retarded thing I've ever heard of. Slow, and I find most of the time more jerky and unsmooth -- At least the people that I've seen do it.
All ya need is heel-toe.
Old Feb 11, 2005 | 12:56 PM
Chazmo's Avatar
Well, I think retarded is unfair. I double clutch all the time and....
Well, OK, maybe I'm a little retarded.
Old Feb 11, 2005 | 12:59 PM
koala's Avatar
It's not completely retarded. If done correctly you can still save wear on your synchros. That being said, I don't bother to double-clutch. It's not worth the added effort on a car such as the S2000.
Old Feb 11, 2005 | 01:01 PM
Chazmo's Avatar
I double-clutch, *and* I'm learning to double-clutch while heel-and-toeing... Is that retarded?
Old Feb 11, 2005 | 01:03 PM
PeaceLove&S2K's Avatar
[quote name='Chazmo' date='Feb 11 2005, 04:01 PM'] I double-clutch, *and* I'm learning to double-clutch while heel-and-toeing...
