What in the hell did I screw up?
Old May 7, 2007 | 05:59 PM
Noizemaker's Avatar
Default What in the hell did I screw up?
Took care of the "couldn't make the screw work" issue. When in doubt get a bigger screwdriver.
Put the top up (but didn't latch it in place) and there's a massive pull. WHAT THE HELL did I do wrong?
Old May 7, 2007 | 06:01 PM
IIGQ4U's Avatar
What are you doing with those metal tools on your car!!!!
You need to check the rain gutter and make sure that the holes on the top are bolted onto the rain gutter. From the looks of it, they are not.
Old May 7, 2007 | 06:13 PM
JackS's Avatar
When all else fails, take your car to a trim shop. You've done the majority of work so someone knowledgeable might be able to finish it off at minimal expense.
Old May 7, 2007 | 07:13 PM
dms2k's Avatar
Just unbolt the bottom section and redo it. Problem solved.
Old May 7, 2007 | 09:00 PM
Noizemaker's Avatar
They definately are bolted in. They were enough of a pain to get in, i know they're there. I'll try again, i guess.
Old May 7, 2007 | 09:25 PM
IIGQ4U's Avatar
No way they are all there and the rain gutter is on properly.
Old May 7, 2007 | 10:47 PM
Noizemaker's Avatar
The rivets were in the way of a lot, but every bolt is down. I'll take pics. Hang on.
Edit: Unless you're trying to say the rivet pulled out of the rainrail, and the rail is bolted down asnd the fabric is above it.
Hrm, i'll check that next time I have a chance to work on it.
Old May 8, 2007 | 07:54 AM
IIGQ4U's Avatar
Can you photograph the entire top? It is not installed properly... Where are you located?
Old May 8, 2007 | 09:48 AM
Noizemaker's Avatar
i'll take pics tonight. I'm in the Portland OR area.
Old May 8, 2007 | 09:52 AM
IIGQ4U's Avatar
Take a lot of photos with as much detail as you can.
