What is this and how do I remove it?
Old Apr 13, 2017 | 08:56 PM
glysomed's Avatar
Default What is this and how do I remove it?
Previous owner had some sideskirts installed and I didn't like them, remove them to find this super strong adhesive underneath at the front and back ends.
It's on the car really good, I tried tugging but i feel like it might take the paint with it if I pull too hard.
It's slightly squishy, anyone know what it is and how I can safely remove it?
Any help is appreciated! Thanks.
Old Apr 13, 2017 | 10:40 PM
stickyfingers's Avatar
That looks like urethane adhesive. It's extremely a pain to take off without damaging the paint.
I would bring it to a body shop and see if they could remove it without damaging the paint. Unfortunately there's a chance that those panels may need to be repainted.
Old Apr 14, 2017 | 08:16 AM
cdubea's Avatar
Ouch. Good luck.
Old Apr 14, 2017 | 02:20 PM
NNY S2k's Avatar
I would bring it to a body shop and see if they could remove it without damaging the paint. Unfortunately there's a chance that those panels my need to be repainted.
Levi
Old Apr 14, 2017 | 04:53 PM
s2cho's Avatar
lmfao, go buy some side skirts and cover that up, only solution unless you wana get it repainted. Sorry for laughing.
Old Apr 14, 2017 | 08:26 PM
HarryD's Avatar
Before the bodyshop route... Try heat gun, Goo Gone, and alcohol?
Old Apr 15, 2017 | 12:38 AM
Anualmix's Avatar
Damn
Go to a bodyshop..
Old Apr 15, 2017 | 05:10 AM
MrFunk's Avatar
This.
Take your time and try and "melt" it off with the above. I'd first try and shave as much off very carefully with a blade (if you have a steady hand). Then heat gun with goo gone. LOTS of it.
Brutal.
Old Apr 15, 2017 | 08:19 PM
cosmomiller's Avatar
Top Answer: 1
Try the heat/scrape off with plastic instruments. Then try MEK. Let it soak in. Pry up the edges and dribble a little more on.
https://en.wikipedia.org/wiki/Butanone
Old Apr 16, 2017 | 07:00 PM
s2cho's Avatar
I'll tell you right now heats not going to do jack to that, that is more or less liquid nails. Construction grade adhesive.
