what kind of Maintance
Old Oct 2, 2003 | 10:32 AM
USAF$2000's Avatar
Default what kind of Maintance
I am going to florida to get a S2000 and I was wondering what kind of maintance it requires I talked to a dealership and they said something about getting the valves and lifters maintanced regularly just wondering what you guys had to say about this thanks and I really appreciate it
Old Oct 2, 2003 | 10:42 AM
Strike's Avatar
Generally speaking this car requires no more maintenance than any other car. That's one of the nice things about it. Certainly it couldn't hurt to have the valves checked and adjusted somewhat regularly but I've only done it once on my car and I have 80k miles on it.
Old Oct 2, 2003 | 11:15 AM
3ngin33r1's Avatar
Get ready for a really long post by me...
Maintenance Schedule for Extreme Conditions.
This schedule is to be followed if you drive in one or more of these conditions most of the time:
Trips of less than 5 miles (less than 10 in freezing weather)
Extremely hot weather (over 90 degrees F)
Extensive idling or stop-and-go driving
Trailer towing, driving with a car-top carrier, or driving in the mountains
Muddy, dusty, or de-iced roads
3,750 mi/6,000 km
Replace engine oil and filter.
7,500 mi/12,000 km
Inspect front and rear brakes.
Check tire inflation and condition.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
11,250 mi/18,000 km
15,000 mi/24,000 km/1 yr
Replace air cleaner element.
Check parking brake adjustment.
Replace rear differential fluid.
Lubricate all hinges, locks, and latches with multi-purpose grease.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
#Inspect exhaust system.
#Inspect fuel lines and connections.
Check all lights.
Inspect the underbody.
# = See information on maintenance and emissions warranty, last column, page 151 of your owner's manual.
18,750 mi/30,000 km
22,500 mi/36,000 km
26,250 mi/42,000 km
30,000 mi/48,000 km/2 yrs
Check all lights.
Inspect drive belt.
Replace dust and pollen filter*.
* = See dust and pollen filter on page 187 of your owner's manual for replacement information under special driving conditions.
33,750 mi/54,000 km
37,500 mi/60,000 km
41,250 mi/66,000 km
3 years
Replace brake fluid (independent of mileage).
45,000 mi/72,000 km/3 yrs
Check all lights.
48,750 mi/78,000 km
52,500 mi/84,000 km
56,250 mi/90,000 km
60,000 mi/96,000 km/4 yrs
Check all lights.
Inspect drive belt.
Replace transmission fluid.
63,750 mi/102,000 km
67,500 mi/108,000 km
71,250 mi/114,000 km
75,00 mi/120,000 km/5 yrs
Check all lights.
78,750 mi/126,000 km
82,500 mi/132,000 km
86,250 mi/138,000 km
6 years
90,000 mi/144,000 km/6 yrs
Check all lights.
Inspect drive belt.
93,750 mi/150,000 km
97,500 mi/156,000 km
101,250 mi/162,000 km
105,000 mi/168,000 km/7 yrs
Replace spark plugs.
Inspect valve clearance.
Check idle speed.
Check all lights.
108,750 mi/174,000 km
112,500 mi/180,000 km
116,250 mi/186,000 km
120,000 mi/192,000 km/8 yrs
Check all lights.
Inspect drive belt.
9 years
120,000 mi/192,000 km/10 yrs
Replace engine coolant, then replace every 60,000 mi/96,000 km/5 yrs.
Maintenance Schedule for normal conditions:
7,500 mi/12,000 km
Replace engine oil.
Replace engine oil.
Replace engine oil filter.
Check all fluid levels, condition of fluids and check for leaks.
22,500 mi/36,000 km
Replace engine oil.
Replace engine oil.
Replace dust and pollen filter.
Inspect drive belt.
37,500 mi/60,000 km
Replace engine oil.
3 years
Replace engine oil.
52,500 mi/84,000 km
Replace engine oil.
Replace engine oil.
Inspect drive belt.
Replace engine oil.
75,000 mi/120,000 km/5 yrs
Replace engine oil.
Replace engine oil.
6 years
Replace engine oil.
Inspect drive belt.
Replace engine oil.
Check idle speed.
Replace engine oil.
Replace engine oil.
Replace engine oil.
Inspect drive belt.
9 years
Old Nov 7, 2003 | 10:27 AM
koshiro's Avatar
What are reasonable costs for 15K and 30K maintenance and where do you go? My honda dealer wants to charge me $260 for my 15K maintenance, does that seem too much?
The only other car I've owned was a corolla and the only maintenance it ever got were fluids and oil.
Old Nov 7, 2003 | 10:37 AM
axis_of_evil's Avatar
I really do wonder how much of that 15K service for example is fluffy BS. Not that I want to ignore my car, but won't it probably be Ok if my door hinges go unlubed for a while?
Old Nov 7, 2003 | 10:43 AM
Hockey's Avatar
The 15K service is basically;
1. Oil change ($30 dino, $60 synth @ JiffyLube or whomever)
2. Diff Change ($23 @ Jiffy.....)
3. Replace Air Cleaner Element ($23 from site sponsors and DIY)
The rest is BS, look at this, inspect that, whatever. If inspections are so important to you, you can easily look and touch just like they do.
You can certainly stretch the life of the diff fluid as well. Unless you track and/or drive the car like you stole it, the diff fluid can go alot longer than 15K. I recently changed mine @ 30K miles and it looked SOOO good, the guy double checked with me to see if I still wanted to replace it (and I did).
Don't give into the OVER-INFLATED dealership service.
You can do as well or better out in the real world, and save a hell of alot of dough.
Old Nov 7, 2003 | 10:51 AM
Good - I concur that feedin the dealer for changing my oil & diff fluid ( which I've done 5x and 1x respectively already by 12K) is totally frickin dumm. Hopefully my tie rods wont explode on the way to work Monday.
Old Nov 7, 2003 | 10:53 AM
3ngin33r1's Avatar
I do all of mine at home.
Old Nov 7, 2003 | 11:12 AM
slalom44's Avatar
Top Answer: 1
Personally, I think most of the things in the 15K service is fluff. If you change your own oil, you're doing a pretty good visual inspection of the underside of your car already. If something looks greasy or banged up, then take a closer look. If you've never curbed or bottomed out your car, then a superficial inspection is all you need. Of course, changing the rear diff fluid should be done (if not sooner).
If you don't know what you're looking at, jack up the front of your car, buy a 12-pack of beer, and invite a friend that's into cars over to take a peek (make sure you have the car on jack stands and the rear wheels blocked if someone crawls underneath). Go down the list with him, and check it off when he's looked at it. If he's really into cars, he may even buy the beer just to have the opportunity to crawl under your car and see what it's got.
Valve adjustment isn't required until 105,000 miles, but if you want to keep it running at optimum performance you may want to consider doing it earlier. I wouldn't worry about lubing the hinges unless they squeak or they see a lot of dust & dirt.
3ngin33r1: We need to give you an award for being a walking reference manual!
Old Dec 9, 2003 | 05:01 PM
jrrogers's Avatar
When adding oil between oil changed what oil does everyone use? Brand/store/etc?
Thanks
