What to look for in used s2000 '2000
Hi everyone,
i'm new to the forum and I already need advice
I found a really nice s2000 for sale (in canada)
it's a sterling silver year: 2000
65,000 KM ~ 40000 Miles
27, 800$ ~ 22,773.82 US$
It sounds like a good deal for here in Canada (ontario) , I was curious to know if you guys think it sounds good too.
The seller says the car is in mint condition
I was wondering what I should look for before buying it, what tests I should do and what problem I might find on an '2000
I have a 2000 model...it's a fun car, although I didn't do a lot of research before buying the it.
Couple things to note:
1. Check the condition of the top; is it faded? How is the plastic window? Is it cloudy, scratched? Ask the owner how he treats the top/plastic window.
2. Check the wearholes...all 00 and 01's will develop them at some point because they have a manufacteur defect.
3. Other than that...I would just use common sense when checking it out.
Oh, and it sounds a bit overpriced but that's just me.
-Chris
Originally Posted by acurateg95,Oct 31 2004, 12:35 PM
Hi everyone,
I'll have to say that the car is way overpriced. Some MY2000's are selling closer to 15k with higher mileage.
Good luck.
- Convertible top wear. Check for wear holes as mentioned above.
- Convertible plastic window. Use Plexus plastic cleaner to
- You might also want to have a mechanic do a compression test on the engine. Some guy posted that he recently purchased a MY2000 S2000 and cylinder #3 had a low compression reading.
- Check the wheel alignment to determine suspension and/or frame damage.
- Check the seams along the body panels for irregularities that might indicate body damage and repair.
Good luck.
