what should i replace?
Old Mar 25, 2009 | 12:08 PM
ar311unity's Avatar
Default what should i replace?
so i just got my s2000 last week...its an 03 with 42,000 miles....the previous owner only had it for 9 months and did not have any maintenance records other than an one oil change record....so my question is..what does everyone think i should check and replace? im definitely going to replace the intake air filter and the cabin air filter...anything else? diff fluid? tranny fluid?
Old Mar 25, 2009 | 12:12 PM
$Piker's Avatar
yes and yes. Clutch fluid as well.
Old Mar 25, 2009 | 12:17 PM
LuDawg's Avatar
Better to be safe then sorry
Old Mar 25, 2009 | 12:18 PM
ar311unity's Avatar
i will definitely do that...how big of a difference will i notice in the way it drives by replacing all the above said items
Old Mar 25, 2009 | 12:22 PM
xeuxx's Avatar
There is no way for us to know since you don't have records of previous work done nor do we have a chance to drive it now.
It could be night and day or virtually no difference.
Old Mar 25, 2009 | 12:28 PM
LuDawg's Avatar
Now thinking about it....I would recomend replacing the stock air filter with a K&N filter. I also felt that the car was not as notchy when I changed the transmission fluid. Just smoother all around.
LuDawg
Old Mar 25, 2009 | 01:04 PM
CKit's Avatar
Blinker fluid.
Make sure you take a good look at brake pad and tire brand and inner edge tread remaining.
Old Mar 25, 2009 | 01:20 PM
thebig33tuna's Avatar
i'd check the clutch fluid, dunno about replacing it... you should be ok assuming your CMC isn't leaking like mine.
Old Mar 25, 2009 | 01:31 PM
Ted H's Avatar
Brake fluid. It's rarely an issue, but when it is, it is. It's worth a flush.
Old Mar 25, 2009 | 01:49 PM
Saki GT's Avatar
Follow the owner's manual.
