what should i replace?
Old Mar 25, 2009 | 05:30 PM
starchland's Avatar
Im a new owner, and Im eventually trying to do all the fluids.
Its nice to know you have fresh fluid and the piece of mind that goes with it.
air filter
oil/filter change
trans fluid - honda mtf II
Diff fluid
coolant/check hoses/etc
clutch fluid
check tire pressure,etc.
check battery levels -top it up if need be
check spark plug condition
check belts for cracks/fraying/etc
theres really not too much that this car needs aside from fluids
Old Mar 25, 2009 | 05:57 PM
zzziippyyy's Avatar
Originally Posted by CKit,Mar 25 2009, 06:04 PM
Blinker fluid.
Bro, replace all your fluids look at your brake pads if worn replace them.
The only thing i wouldnt run to replac eif it test good is your coolant.
Old Mar 26, 2009 | 05:38 AM
takeshi's Avatar
All fluids unless you're certain that the previous owner took care of them (from what you've stated it doesn't sound like you can). Check other wear items and replace as needed.
Originally Posted by ar311unity,Mar 25 2009, 12:18 PM
i will definitely do that...how big of a difference will i notice in the way it drives by replacing all the above said items
As someone has already stated there's no telling (probably not much except for tranny and diff) but you want a known point of reference for future maintenance. Unless you're going to assume that all the fluids were fresh at the time of purchase (I seriously doubt it) and start the counter for everything at zero.
Replace all the fluids. "Feel" is of very limited use in these cases.
accordr33
Apr 26, 2007 02:09 PM
SWFLS2K
Sep 7, 2006 12:18 PM
Tx_Phantom
Aug 15, 2006 10:16 AM
r_duff
Aug 17, 2004 07:03 AM
allkingz
Jul 17, 2003 12:37 PM
