what is the top speed of the S?
Old Feb 11, 2008 | 06:31 PM
Planets's Avatar
AP1 is ~155mph drag limited and gear limited around 170mph I believe if you have enough power to overcome the drag.
Old Feb 11, 2008 | 06:33 PM
Enthralled's Avatar
I always thought the AP1 was 165mph and AP2 was 155mph.
Old Feb 11, 2008 | 06:38 PM
__redruM's Avatar
The AP2 is Gear Limited to about 151-154. The AP1 is Drag limited to about 150ish, but with boost, the AP1 will get up to about 171ish at the rev limiter.
Old Feb 11, 2008 | 06:40 PM
Funat9's Avatar
theres only one way to find out!!
road trip to the autoban with cameras and lets see some results live and raw! and maybe an ambulance if someone crashes......
Old Feb 11, 2008 | 06:51 PM
dr.darkness's Avatar
159 stock 4am on the freeway still had more.
Old Feb 11, 2008 | 07:01 PM
J'sS2K's Avatar
145mph, stock, then the radar detector started to beep. I could have gone a bit higher.
Jason
Old Feb 11, 2008 | 07:06 PM
ATOice's Avatar
It's in the 160's or low 170's. I have only had it to 120...no need for more. Good luck hitting top-end if that's what you are looking for.
Old Feb 11, 2008 | 07:24 PM
rnye's Avatar
148 Top down, Houston, TX with 4 other S2000s. I have the lip and wing, and passenger - the other S2000s were still pulling slightly - so I think I was definately drag limited..
Old Feb 11, 2008 | 07:26 PM
Tyraid2K's Avatar
wtf I though the AP2 had a longer 5th and 6th gear for cruising?
Old Feb 11, 2008 | 07:28 PM
Enthralled's Avatar
yes it is, but the first four are a bit shorter.
