whats inside of an f22c?
Old Oct 23, 2007 | 10:35 AM
alejo's Avatar
Originally Posted by rocrfella,Oct 23 2007, 11:32 AM
Ask the god damn manufacture. Even Jesus doesn't know this one.
rocr: ask Jesus if using the same joke in every post on S2KI kills the humor in it
Old Oct 23, 2007 | 10:54 AM
Saki GT's Avatar
http://corporate.honda.com/press/article.aspx?id=4096
[QUOTE] 08.15.07
2008 Honda S2000 - Powertrain
The S2000 powertrain uses a front-engine/rear-wheel-drive layout. The longitudinally mounted engine is mated to a 6-speed, close-ratio manual transmission. A driveshaft carries the output of the transmission to a frame-mounted Torsen limited-slip differential. The differential drives the rear wheels via independent axle shafts. The 2.2-liter, aluminum-alloy, inline 4-cylinder S2000 engine (engine code F22C1) produces 237 hp @ 7800 rpm and 162 lb.-ft. of torque @ 6800 rpm. The aluminum alloy cylinder head has dual overhead camshafts, four valves per cylinder and VTEC (Honda's variable valve-timing system) on both the intake and exhaust valves. Fuel induction is via Honda's sequential, Multi-Point Programmed Fuel Injection (PGM-FI) and the ignition system is a high-voltage, computer-controlled direct type with individual spark coils for each cylinder. The engine's exhaust emissions qualify the S2000 as a California Low-Emission Vehicle 2 (LEV-2) and EPA Tier 2, Bin 5 vehicle.
Powertrain Summary
2.2-Liter (2157 cc) VTEC Engine
Old Oct 23, 2007 | 11:12 AM
rocrfella's Avatar
Originally Posted by Saki GT,Oct 23 2007, 10:54 AM
Old Oct 23, 2007 | 02:12 PM
S2KMiyo's Avatar
Originally Posted by Soul Coughing,Oct 16 2007, 01:10 PM
im almost certain its not a CF driveshaft.
CF driveshafts are on Z's.
Old Oct 23, 2007 | 02:29 PM
INTJ's Avatar
Why isn't this RTFM/RTFF?
Old Oct 23, 2007 | 02:49 PM
SheDrivesIt's Avatar
Because most of this shit isn't in the manual. However, most of the questions were answered in the linked and quoted specs.
Old Oct 23, 2007 | 04:43 PM
Saki GT's Avatar
Yeah, obviously you did not read the manual, or you'd know that.
Old Oct 24, 2007 | 05:49 AM
street_ruler's Avatar
actually cf driveshafts are on rx8's too as an option but i didnt know it was on the Z. thats cool
and for the replies...thanks that huge quoted one is a gold mine
Old Oct 24, 2007 | 05:52 AM
i noticed this was published in 07....are all these things true f9or earlier ap2's?
Old Oct 24, 2007 | 07:55 AM
INTJ's Avatar
RTFF-FAQ
