what's a normal dynopack # for the S with I/H/E?
Old Jun 29, 2006 | 08:28 AM
revto9k's Avatar
Default what's a normal dynopack # for the S with I/H/E?
what's a normal dynopack 5000 # for the S with I/H/E
Old Jun 29, 2006 | 08:31 AM
Sideways's Avatar
The Church Dynapack dynoed several year '00 stock and they averaged 213 rwhp. Intake, headers and exhaust might add a few ponies to that number but usually not above 220 range from what I recall.
Old Jun 29, 2006 | 12:04 PM
zyr's Avatar
zyr
AP2s dyno on church's dynapack dyno for about 225-230 stock. I've seen I/H/E dynos on church's dynapack for 240 range.
Old Jun 29, 2006 | 01:39 PM
revto9k's Avatar
are we talking about dynopack 5000, not dynojet? just making sure we are talking about : http://www.dynapack.com/dynapack.html
this dyno has 350z with I/H/E dynoed at 220.
wouldn't a 4.44 FD mess up dyno reading? if I am not mistaken hp # is measured as some factor X torque X RPM, and most dynos are just measuring how much force needed to stop the wheel from spinning (aka, torque).
Old Jun 29, 2006 | 02:15 PM
Sideways's Avatar
As long as the ratio is entered correctly gear changes will not make a difference in the reading.
A stock AP-1 with 4.10 rear end gears would have 5.521 as a ratio using 4th gear.
If 3rd gear is used then a ratio of 7.044 should be used, if 5th gear is used then a ratio of 4.618 should be used.
Ratios can be obtained from http://www.turnzero.com/technical_resource...gear_calculator
TCF should be zero.
Old Jun 29, 2006 | 05:31 PM
revto9k's Avatar
hey sideways, so on a dynapack a 350z with i/h/e should make more than 220?
I am trying to figure out my dyno result, my # is low compared to what an S should make on dynapacks, yet my compression is 210s across, leak down tests came clean. I was told a stock s2k should make about 170-180 on dynapack.
Old Jun 29, 2006 | 06:04 PM
Sideways's Avatar
I have never seen a healthy stock s2k put down 170-180 on a Dynapack. 200 to 240 is what I have seen. 170-180 sounds like a Mustang dyno.
As for a 350z check out these threads:
http://my350z.com/forum/showthread.php?t=192512
http://my350z.com/forum/showthread.php?t=177503&page=5
Old Jun 29, 2006 | 07:01 PM
revto9k's Avatar
thanks sideways
umm, this dyno reads 350z's # low too. by ratio wise 200s on the dyno I've been using should be sth like 230s on other dyno...
it's not a mustang dyno for sure. is there anyway the dyno could be configured wrong? or does dyno loose accruacy over years? speed seems to match.
wait I just remember sth, this particular dyno was mostly used for 4wd cars, I am no expert on dynos, doesn't 4wd needs different configuration?
Old Jun 29, 2006 | 08:17 PM
afwfjustin's Avatar
That completely depends on which header and exhaust you have. If you have dc header and comptech exhaust, you'll probably have zero gains over stock.
Old Jun 29, 2006 | 08:19 PM
Series10's Avatar
I dyno'd on Church's dynopack at 232. '05 with only intake, tp, exhaust and VAFC (version 1).
