what's the trick?
Old Aug 10, 2006 | 10:05 AM
gottaride's Avatar
Default what's the trick?
O.K. ....it seems nothing's easy. What's up with the plugs? When I try to push them in, the brass threaded nut seems to back out and won't receive the plugs prong. It doesn't appear that I can get behind it and hold it in place either. Anybody got a clue as to how to install them without disassembling the car? Thanks in advance
Old Aug 10, 2006 | 10:09 AM
North Star's Avatar
Hmm, that's odd.... Mine pushed right in snug, with no problems?
Sorry about your luck!!
North Star's Avatar
Deleted dupe post!
CosmosMpower's Avatar
Is this a joke? They just plug right in like an outlet into a wall for your vacuum cleaner. You might have wrong plugs or something if it doesn't just push in.
Old Aug 10, 2006 | 10:11 AM
hatch4raceb16's Avatar
This happened to me, theres not good way of doing this. You will need to remove the entire bumper as the metal pieces on the inside have pushed back.
No other options to get them on right.
Take off the bumper, you will see what I mean.
Old Aug 10, 2006 | 10:19 AM
gottaride's Avatar
you're kidding....pull the bumper off?? Christ, I'll just put the License plate holder back on
Old Aug 10, 2006 | 10:26 AM
vsm2k's Avatar
happend on my car too. the plates are held by these tiny rubber studs, on of which was broken therefore not allowing me to push in the plug, or the bolt for the license plate frame. I had to take the bumper apart and pretty much glue the stud back in place.
Old Aug 10, 2006 | 10:32 AM
i_heart_my_DB8's Avatar
If the brass nut has retreated too far into the bumper, carefully thread one of the license plate mounting bolts into the nut, and then pull it back toward the bumper.
If you want, use an xacto knife to trim the prongs of the plugs so they don't require as much effort to insert. Don't worry, they're not going to "pop off" at speed as long as there's some friction holding them in there.
I'm guessing this doesn't work for the S2k since nobody has suggested yet, but with my Integra, I could slip my hand in the air dam, and pull the styrofoam bumper piece toward me as I inserted the plugs, to make sure the brass nut didn't go anywhere.
Good luck!
Old Aug 10, 2006 | 10:34 AM
xviper's Avatar
If you don't want to pull the bumper, just use a little silicone seal and glue the plugs to the front bumper.
Old Aug 10, 2006 | 10:48 AM
gottaride's Avatar
I'd already considered pulling it back in place with one of the bolts. I don't unerstand why the things aren't just 4 bolts with painted heads. I may just go get bolts that thread into each hole with rounded heads and then just get some touch up paint from Honda and paint the heads....what Honda should have done to begin with.
