where to buy 220ft/lb torque wrench?
Need help guys the highest torque wrench autozone has is 150ft/lb....... where do you guys get your torque wrench to re-torque the rear axle nut? i'm just afraid the clicking sound will run my wheel bearing and hub sooner or later ( even afraid to join HPDE)
thanks a lot
p/s:any tips on how to take out the axle nut ? should i sit the car down with the tires on the ground or jacked up with the transmission in gear?
thanks a lot
Originally Posted by chairmnofthboard,Sep 21 2007, 04:45 PM
Impact gun works fine. as long as it's strong enough.
there's impact gun that doesnt 100-1000 lb/ft
depends on the PSI
don't get it on superman tight tho
Originally Posted by iam7head,Sep 21 2007, 04:49 PM
not exact sure what you mean.
depends on the PSI
depends on the PSI
If a gun say's 100 ft-lbs forward, that doesn't mean the nut/bolt is tightened to a 100 ft-lbs. usually a lot less. My experience at least.
