Where can I buy exhaust flanges?
Ok here is the plan. I am going to be welding up a custom stainless steel exhaust section that will be replacing the section between the catalytic converter and the section with the dual exhaust cans. So I need to buy stainless steel flanges that would bolt up to the catalytic converter and to the rear section of my Invidia.
Does anyone know where I would be able to obtain these two pieces?
Here are some pictures with arrows pointing to the parts I need
If you can't find one at you local parts store or muffler shop try this link.
verocious motorsports
Good luck.
Good luck.
Originally Posted by JackS,Nov 1 2006, 08:06 PM
Is it the mandrels your trying to eliminate i.e- a straighter pipe?
And no I am not making it to remove the bends. I plan to make an extra mid pipe with a different resonator or muffler or something to keep the sound down a bit and keep the invidia look out the back.
You can try vibrant performance. Burn's is though
http://vibrantperformance.com/catalog/inde...343a081d379f2e1
the isocelese triangle flange probably needs to be costom made. i looked all over and emailed a few manufacurers and they all told me that they cant get me that piece. long story short i just took a gasket and had a fabrication shop water jet it out of 304 sus. but at a high cost of $55 per flange. at the time i was making 2 test pipes. in anycase that will be expensive the 2 bolt 2.5" flange is easy to find. vercious motor sports sells like the above post but i searched around and found that sfxperformance.com sells the same Vibrant flange for a bit cheaper but they are a bit over 2.5" in diameter. i went through this whole spiel of having to find stainless flanges
markfromaurora
11-05-2008 09:51 AM
