Where can I get lighter rotors?
What are you trying to achieve? Lower unsprung mass? Typically rotors are a bad place to look for this sort of weight reduction, as you reduce your brakes cooling capacity... At least that's what I've always read.
Originally Posted by PJCC,Dec 1 2007, 11:44 PM
Yes, but that's for fast track cars that are driven hard. He has a fast rear end busting turbo'ed S, so he does not need the heat dissipation capacity.
seems there was a thread like this last week.
car peeps are negative for any rotor material other than cast iron. and then only universally accept the most heavy pickup truck setup's. in comparison to sportbike riders who go the other way. think of the vehicle weight differences in both situations.
thebrakeman.com
i am sure there are alternatives here, but to make any significant change is expensive.
the 18" wheels eat up any weight savings anyways so to cram a better brake system into a oem" wheel is a ponder
thebrakeman.com
Originally Posted by TB,Dec 2 2007, 09:59 AM
So you're saying that he made his car faster, so he needs to reduce his braking ability?
and with regards to bikes - it's definitely cheaper and there's a whole hell of a lot mass to stop.
Yeah I know the Wilwood's are a good option - I actually posted this thread for a fellow s2katlanta club member. I remember there being a forged aluminum rotor that came out around a year ago and I couldn't remember the name.
Unless he road races the car, which requires constant braking for extended periods of time, he might be able to reduce the rotor mass and still keep good one-time braking capacity. A stop from 120 in the 1/4 mile with 10 minutes cool-down breaks is not constan braking.
