Who blips their throttle when they are downshifting?
Originally posted by jwkim
I do double clutching to make downshift even smooother
When it is needed I do heel and toe and double clutch at same time too
Originally posted by heffergm
Why the hell would you double clutch downshifts on a transmission with synchos? There's absolutely no need.
Double clutching makes gear downshift much easiler and smoother..
Try to put into 1st gear at 30mile without double clutching. Shifter will be much harder to go into 1st gear.
With double clutching, shifter moves without any resistance.
Double clutching saves synchros and you know 00 & 01 has weak first and second gear synchro.
Also with much practice double clutching can be very fast(less than 1 sec)
This issue has been discussed many times.
I guess you NEVER done double clutching...
There's no reason to double clutch downshifts in any modern transmission. Rev matching accomplishes the same thing without the need for the extra work.
If I was planning to downshift into first gear at 30mph, I might in fact double clutch the shift, just to give me enough time to get the RPMs high enough. But outside of a racing situation, a downshift into first at 30mph isn't the brightest move.
So anyway, if it makes you happy, continue double clutching (I'm going on the assumption you actually know what double clutching is, and aren't just equating rev-matching with double clutching... because they're not the same thing).
