Who does intake porting/polishing?
Old Nov 18, 2000 | 10:44 AM
shaner's Avatar
I'll be ordering a Comptech supercharger kit in the late winter/early spring and I wanted to go all out by maximizing flow:
-I'm sending away my throttle body to PowerFlow to be ported/polished
-I will be getting an aftermarket header (not sure who's)
-I have a catalyst replacement on the way (MG Racing)
-I will then be getting a Comptech exhaust system
-To further this maximum-airflow-maddness, I wanted my intake ported and polished (while I have some of the engine already apart)
Who does it? Does anyone agree/disagree with my plan?
Last question: Why is there an antifreeze line running through the throttle body?
Old Nov 18, 2000 | 11:03 AM
VaporTrail's Avatar
You might consider this source for your intake manifold polishing.
Extrude Hone - I've used this process in the past on heads, intakes, turbo housings, etc. On a Integra Type R intake manifold, it showed an increase of 4hp to the wheels. Your results may vary. Basically, the process is forcing an abrasive putty type material through the ports, polishing it super smooth. I liken the finish to that of glass.
Try them out at www.extrudehone.com HTH
Old Nov 18, 2000 | 12:19 PM
Schatten's Avatar
I haven't used EH, but only seen it work on friend's cars - great stuff. do a search for it on this forum and you'll find out more info.
Old Nov 18, 2000 | 12:43 PM
S2K_CLS's Avatar
The coolant line in the TB helps warm the TB in the winter time (prevents it from freezing shut).
detoxclinic
Nov 11, 2016 11:49 PM
seung012
Nov 22, 2005 04:26 AM
BustedShox
Jun 23, 2004 09:14 PM
RevIllusions
Nov 26, 2002 10:00 PM
