wide tires
Old Nov 27, 2006 | 10:22 AM
novatemp03's Avatar
Default wide tires
Im curious, who has put on wider tires and what changes to body did you have to make.
Old Nov 27, 2006 | 10:24 AM
Spec_Ops2087's Avatar
I run 255s in the rear. No changes done to the body. I am not running stock rims though.
Old Nov 27, 2006 | 10:53 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
How much wider???
Old Nov 27, 2006 | 12:37 PM
novatemp03's Avatar
I'm just wondering how wide others have gone and what were the changes required to get there. I read a thread where someone said they went 245 and 275 on an ap2 with only rolling the fender. Have others gone wider with wide body kits etc.
Old Nov 27, 2006 | 12:39 PM
kchandra's Avatar
mind sharing the offset and any suspension modifications (coilovers, any trailing arm modifications) etc...
Thanks!
Old Nov 27, 2006 | 12:48 PM
camera obscura's Avatar
I'm running a 255 on the rear OEM AP2 wheels. My car is slammed and I've still got room to run a spacer. 2.4* camber.
Old Nov 27, 2006 | 12:56 PM
s2kshift9k's Avatar
my friend has 255's on his and those are some fat tires
i like the 245/50/16 set up
Old Nov 27, 2006 | 12:58 PM
Johnny Sack's Avatar
unless your putting a stupid amout of power to the ground, you dont really need any more tire than a 245/255. you can actually have TO MUCH tire on the ground and that will cause a lack of traction. i run 245's out back and have enough traction to run 13.5's with a 2.1 or so 60 ft.
Old Nov 27, 2006 | 01:00 PM
joey17182821's Avatar
Banned
i have 265 on a 18x10 wheels with a +62 offset. camber and rolled fenders needed to run so low.
Old Nov 27, 2006 | 01:02 PM
